What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,111
My dealer provided me with all of the manuals. Not sure if web site or what. I know I have them all on my computer.
   / What did you do on or to your LS Tractor today? #2,112
These help? HST is on the right.
   / What did you do on or to your LS Tractor today? #2,114
Installed the LS 3rd function valve kit today. Came with the solenoid valve, joystick, and wiring harness.
I didn't buy the lines and hardware kit as it cost too much for what is in the kit. I'll make my own out of hose and I purchased a couple bulkhead connectors for the loader mount. I also have some of the hardware in my shop already.
   / What did you do on or to your LS Tractor today? #2,115
Thankfully my XR4155 came from the factory with three remotes , that was one of the big reasons why I bought it.
   / What did you do on or to your LS Tractor today? #2,116
Mine did too. All three rear remotes get used with some implements.
Third function is different than the three rear remotes though. Primary use will be for a future grapple.
   / What did you do on or to your LS Tractor today? #2,117
my xr4150 open station, only came with two remotes. I wish I had at least one more.
   / What did you do on or to your LS Tractor today? #2,118
I’m not sure how that actually works have seen MT3 57 and XR4155 come with either 2 or 3 remotes so I’m guessing it depends on what the dealer happens to order.
   / What did you do on or to your LS Tractor today? #2,119
This is just another data point for regen operation.
After letting my MT240 warm up a couple minutes last night the regen light came on and the temp had barely moved off C which was unusual. It did reach normal temp in a few more minutes and that's when it did the RPM variation which meant it needed to run higher RPM than the 1600 I had it at to regen, so I nudged the throttle up to 1800 and then the High temp warning light came on, this was at 176.7 hrs. I continued the work and at 176.9 hrs the lights went off in usual sequence first the high temp then a minute or so later the regen light. That was a regen in only 12 minutes, the quickest yet, usually they take closer to 20 minutes.
   / What did you do on or to your LS Tractor today? #2,120
Well here's my regen history the best I have record of it, I'm sure I missed a few early on before I recognized there was a real problem. I have been having issues almost since I picked it up. They replaced a sensor, and they now have a ECU on order (backorder.) I even had a few regens and then within 5 minutes it goes into limp mode which a restart clears. There were also a couple regens ran at the dealership during troubleshooting and maintenance which I don't have listed below.
Regens time on hour meter, all regens complete successfully ~12 minutes:
4 (ran by dealer due to error code, day after I brought it home)
101
106
112
(Dealership replaced DPF Sensor)
118
119
148
165
175
187
191
197
213
224
234
250
(Dealership replaced ECU @ 252 hrs)
At one point, LS time told my dealer who told me they did NOT think the regen frequency was abnormal!
They have also blamed the fuel quality, which I get only from 2 sources with high turnover. I told them to sample it and prove the fuel is bad. After that, they ordered parts lol
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2019 PETERBILT 579 DAYCAB (A58214)
2019 PETERBILT 579...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
New/Unused Electric Golf Cart (A57453)
New/Unused...
