What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today?
The purpose of the retrofit kit is to be able to take the 3 point arms easily....
Yes, I know, but it seems like an unnecessary step when switching back and forth for a few minutes. I had them add it so I could take them off if needed, not that I planned to each time. Plus, since I tend to put bolts back in their holes so I don't lose them, they likely would be there even with the arms off.
   / What did you do on or to your LS Tractor today? #1,992
Any chance they used wrong bolts?
   / What did you do on or to your LS Tractor today? #1,993
It wasnt today, but rather a few days ago... But I finally got my EA wicked-er root rake grapple!! Its been a long wait, but I can finally get my projects done! I linked to the video on the general attachments forum under the EA thread. Go check it out!
   / What did you do on or to your LS Tractor today? #1,994
The EA Grapple is my new favorite attachment. The wife is calling me lazy because I try to pick everything up with it.
   / What did you do on or to your LS Tractor today? #1,995
working on fence rows with the shear i built .
   / What did you do on or to your LS Tractor today? #1,999
on the shear it should be able to go up to about 8 inches , it opens up to 10 inches , the weight not sure wanted to keep it around 600 or less , I will take it to work and weigh it out so i will know , it took me 4 times to get it where i wanted the first 2 builds i bent the 3/4 inch blade then bent the the 1.5 " rod on a 4X8 cyclinder , the cyclinder is a 4X16 with a 1 3/4 rod that on it now , the blade is a 1 & 1/4 " thick , i still need to profile it alittle more so it slices through alittle smoother , largest tree so far was about 6 inches round and it cut right through it with no problem at all , most of the tree's I'm shearing is 1 to 3 inches in the fence rolls that has grown up over the last few years , I build most my attachments grapple buckets , road grader , fork lift forks , etc...
   / What did you do on or to your LS Tractor today? #2,000
Installed 2" Bora Wheel Spacers. Needed clearance for snow chains.
2021 CATERPILLAR 926M WHEEL LOADER (A52709)
2021 CATERPILLAR...
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
LOT: (2) Shelving Units w/Equipment Parts & Hardware (TANKS NOT INCLUDED) (A59076)
LOT: (2) Shelving...
Skid Steer 59in Vibratory Roller (New/Unused) (A59225)
Skid Steer 59in...
PNEUMATIC GREASE UNIT (A58216)
PNEUMATIC GREASE...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
