What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,971
Changed the oil/filter in the 4155HC this evening getting ready for a day of brush hogging. Afterwards I fired it up an let it idle in the shop for a few minutes while putting tools away. When I came back to it I noticed a pretty good oil leak coming from under the filter so I shut it down and pulled the filter back off. The oil filter is a bit hard to see as it is behind the FEL upright and quick connect valves. Shure enough a stray blade of Johnson grass had managed to get under the seal.
   / What did you do on or to your LS Tractor today? #1,973
Summer sun was a bit brutal but wanted to get the trench dug. Started searching for some universal canopies when I remembered I had one of these up in the attic not in use. Fits perfectly on the hinge for the ROPS and a large hose clamp secures it in place. Can add it or remove it in less than 2 minutes. Solid solution for what was a $40 purchase years ago. Maybe I'll see if I can find a blue one to match the tractor instead.
   / What did you do on or to your LS Tractor today? #1,974
I bought one for that purpose too, just haven't used it yet. Hadn't thought about using a hose clamp, thanks for the tip.
   / What did you do on or to your LS Tractor today? #1,975
Didn't really like some of the factory switch locations so I moved the PTO, linked pedal, and cruise switches to the right hand console.
   / What did you do on or to your LS Tractor today? #1,976
I love that idea! How much of a PITA was that?!
And what did you do with the spaces left behind on the dash?
White wire on your door?
   / What did you do on or to your LS Tractor today? #1,977
It wasn't too bad. I think it was 10 wires total of I remember right and a couple hours. Labeling the wires and switches made it fairly easy and I wrote it all down for future reference.
The right console has blank plates so I moved those to the dash. The PTO hole I had a black plug to put in there.
The white wine is for a tablet that I use as an engine monitor/gauges.
   / What did you do on or to your LS Tractor today? #1,978
Didn't do anything really constructive.
Set up a fueling station in my barn. This way I can keep 50g of diesel on hand then just fill up with out spilling.
The drum is off the ground and way from everything that could be an issue.
   / What did you do on or to your LS Tractor today? #1,979
Been busy with the LS lately. Never enough time to post much.
Did a little clean up a few days ago. Amazing what a few hours can do with the right equipment.
The Wicked Twin hauling rocks.
The power rake leveling, sorting and windrowing rocks.
And a few passes to clean up.
   / What did you do on or to your LS Tractor today? #1,980
Found some bob wire. The power rake excels at rolling up wire.
Took a solid hour to get all that out.
2016 Case CX55B Midi Excavator (A55973)
2016 Case CX55B...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
LOT: (40 approx. ) Chain Link Fence Panels (A59076)
LOT: (40 approx. )...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
550 GALLON FLAT BOTTOM POLY TANK (A58374)
550 GALLON FLAT...
Boat (A56859)
Boat (A56859)
