What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,971
Changed the oil/filter in the 4155HC this evening getting ready for a day of brush hogging. Afterwards I fired it up an let it idle in the shop for a few minutes while putting tools away. When I came back to it I noticed a pretty good oil leak coming from under the filter so I shut it down and pulled the filter back off. The oil filter is a bit hard to see as it is behind the FEL upright and quick connect valves. Shure enough a stray blade of Johnson grass had managed to get under the seal.
   / What did you do on or to your LS Tractor today? #1,973
Summer sun was a bit brutal but wanted to get the trench dug. Started searching for some universal canopies when I remembered I had one of these up in the attic not in use. Fits perfectly on the hinge for the ROPS and a large hose clamp secures it in place. Can add it or remove it in less than 2 minutes. Solid solution for what was a $40 purchase years ago. Maybe I'll see if I can find a blue one to match the tractor instead.
   / What did you do on or to your LS Tractor today? #1,974
I bought one for that purpose too, just haven't used it yet. Hadn't thought about using a hose clamp, thanks for the tip.
   / What did you do on or to your LS Tractor today? #1,975
Didn't really like some of the factory switch locations so I moved the PTO, linked pedal, and cruise switches to the right hand console.
   / What did you do on or to your LS Tractor today? #1,976
I love that idea! How much of a PITA was that?!
And what did you do with the spaces left behind on the dash?
White wire on your door?
   / What did you do on or to your LS Tractor today? #1,977
It wasn't too bad. I think it was 10 wires total of I remember right and a couple hours. Labeling the wires and switches made it fairly easy and I wrote it all down for future reference.
The right console has blank plates so I moved those to the dash. The PTO hole I had a black plug to put in there.
The white wine is for a tablet that I use as an engine monitor/gauges.
   / What did you do on or to your LS Tractor today? #1,978
Didn't do anything really constructive.
Set up a fueling station in my barn. This way I can keep 50g of diesel on hand then just fill up with out spilling.
The drum is off the ground and way from everything that could be an issue.
   / What did you do on or to your LS Tractor today? #1,979
Been busy with the LS lately. Never enough time to post much.
Did a little clean up a few days ago. Amazing what a few hours can do with the right equipment.
The Wicked Twin hauling rocks.
The power rake leveling, sorting and windrowing rocks.
And a few passes to clean up.
   / What did you do on or to your LS Tractor today? #1,980
Found some bob wire. The power rake excels at rolling up wire.
Took a solid hour to get all that out.
2016 Winco Standby PSS8B Generator (A54865)
2016 Winco Standby...
(APPROX. 20) 4' X...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
