What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #841
Mounted new FM BH8 backhoe today for 1st time. Just picked it up Tues. Took a few days to assemble due to wx and other things.
Seems very well built and very nice fit and finish. My Kioti bh was a subframe so this was quite different. Have to be very close to hookup PTO for hydraulics. I can see where having a proper dolly will be quite an asset. Thinking sometime in future I may convert to a subframe, but would have to custom build.
Controls are ISO configuration, so I either relearn or change plumbing. A bit counter intuitive that dipper movement is opposite of valve.
Didn’t get any productive work done as current project requires just a small bucket or maybe the ripper. Unfortunately neither would mount, bushings on inside of mounting plates.
View attachment 624591View attachment 624592.
Will be contacting dealer for resolution
I guess there’s no standard for BH buckets? Are the mounts different for various BH makers?
   / What did you do on or to your LS Tractor today? #842
I believe you are right. Years ago I was in need of a narrow bucket for my Kioti. Friend offered his Kubota bucket. Not even close.
An internet search revealed all sorts of variance. Maybe things are better these day, don’t know and hoped to avoid by buying with the bh.
I’m guessing I could either grind these down and wonder if strong enough or take to a shop and have them fix. No idea the expense.
Will wait for instructions from Betstco.
   / What did you do on or to your LS Tractor today? #843
Looks good when you get the extra bucket and ripper working let us know how they work and if worth buying!
   / What did you do on or to your LS Tractor today? #844
On my Boomer 40, XR3140, I rewelded the hydro pedal stops. Had to raise them about an inch to get full travel. Noticed the problem when the GPS speed would only read half of the stated speed going forward and a little less in reverse.
From what I saw on the dealership lot the tops models were fine but the cab models had the same problem mine has.
   / What did you do on or to your LS Tractor today? #845
Got the Kohler wrestled into place yesterday.
A bit of help from my LS
Propane hooked up - no leaks
Generator side wire connections made
Still need to install battery
Make up the house side connections, inverter, transfer switch and fire it off
Nothing (again). And it's getting lonely (again).
I did spend a few hours working on the newly renovated house (OK, shed) for it if that matters.
   / What did you do on or to your LS Tractor today? #847
Continuing to build more burn piles, from tree trimming.
   / What did you do on or to your LS Tractor today? #849
We enjoy "Chipping" rather than "Burning". This past summer's wildfires were chokingly smokey and nasty and we'd rather not add to the stink.
Ok then.
I'll bet you'd really enjoyed "chipping" this?
Or this?
Or these?
I might be trying to find a way to chop and sell them for firewood.
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
2014 BMW X1 AWD SUV (A56859)
2014 BMW X1 AWD...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
