What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #711
Grappled a bunch of blow down from windstorm that must have come through last week. Nothing like sitting in air conditioned comfort with tunes on while working
   / What did you do on or to your LS Tractor today? #712
Yes I wont be buying another tractor without cab at least not for me to use maybe when kids get little bigger I will get one for them lol
   / What did you do on or to your LS Tractor today? #713
Thanks Guys.
Ordered a set along with nylon washers.
Mine arrived today. Had to cut off about half inch.
Still not happy with the screen itself. Apparently have to lift FEL full height to clear tire.
I can see a future mod to make the screen 2 panels to facilitate removal.
Did a bunch of tilling, breaking up some ground for next year (hopefully) and turning the corn under after cutting it down with the field and brush mower. Lots of hard spots and some bouncing around. Hope nothing broke.
   / What did you do on or to your LS Tractor today? #715
Yep. You gotta move the FEL up to get good access to the engine. I just do it outta habit. Makes life easier all around the engine compartment with the FEL up.
   / What did you do on or to your LS Tractor today? #716
Bar installed.jpgEvery time I get under the hood, I raise the FEL to the top, Habit also.
My Piranha Bar came last night. Time to see if the hype is true.
   / What did you do on or to your LS Tractor today? #717
David, when you clean screen and blow out radiator, park on level surface, raise the FEL, and turn front wheels full left. You should have plenty of clearance to remove and re-install your screen.
   / What did you do on or to your LS Tractor today? #718
Last night I helped my neighbor dig some holes for the concrete piers for his new deck. Using my new (to me) Woods BH. It was pretty awesome!
   / What did you do on or to your LS Tractor today? #719
Nice 🤙
How does your BH mount?
Part of me really wants to keep my Kioti BK, but need to figure out how to mount as the subframe is different.
   / What did you do on or to your LS Tractor today? #720
I have a cheap old say 14 years 3 point mount backhoe and I know a frame mounted one works better but I found ways to make it work better with chains to hold it up taking weight off 3 point and with adjusting bars to hold it down against the chains! Dont know if that's possible for your backhoe?
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
NEW Wolverine 36in Skid Steer Grapple Bucket (A59000)
NEW Wolverine 36in...
2021 CATERPILLAR TL943D TELESCOPIC FORKLIFT (A52705)
2021 CATERPILLAR...
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
