What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,321
Looking great
Ahhhhhh ......
Purchase total was a little under $19K. If I had paid the monthly payments as set in the contract, I would have paid a little under $22K and payoff would have been in October of '25. By paying about $40 extra each month, I knocked it down to where I could make a few bulk payments (Stimulus Checks, sold items, etc.) and bring it down to where I could pay it off a full three years early with a total amount paid of a little over $20K saving around $1,300 in interest.
   / What did you do on or to your LS Tractor today? #2,324
Ahhhhhh ......
Well, I think congrats are in order!
   / What did you do on or to your LS Tractor today? #2,325
So I got my MT573 a little over a month ago. I have been too busy working on my house to do anything with it.
A local guy came by this weekend to pickup all my old scrap from the remodel. I had an old heat pump that weighed maybe 400-450lbs. I have a set of those clamp on forks for moving small stuff around that I have been using with my JD. I knew the JD would not pick up the heat pump so I put the forks on the new LS to pickup the heat pump to put on the scrappers truck.
When I lifted the heat pump the bucket bowed out of shape. I was a little surprised since I never had the JD do that. I ended up strapping heat pump and lifting it that way to load it.
The bucket did go back almost to it's original flat shape on the blade edge.
   / What did you do on or to your LS Tractor today? #2,326
Congrats, Diggin, well done
   / What did you do on or to your LS Tractor today? #2,327
TimberFarm, maybe add a reinforcement to your bucket?
   / What did you do on or to your LS Tractor today? #2,328
I was thinking of buying that Extreme edge from Everything Attachements. That should stiffen the bucket edge up. A little pricey at $664, but the alternative is an aftermarket bucket that is heavy duty.
   / What did you do on or to your LS Tractor today? #2,329
TimberFarm. I bent mine in clay. I bent it back and put a wicked edge on. For sure worth the few hundred bucks. I would recommend you ask them to make the side tabs longer or lower. Mine ended up on the corner of a welded on strengthening plate.
   / What did you do on or to your LS Tractor today? #2,330
Thanks for that tip.
I will have to take a close look at mine.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A58018)
2014 FREIGHTLINER...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
New Wolverine 3Pt hitch Receiver (A59000)
New Wolverine 3Pt...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
