What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,321
Looking great
Ahhhhhh ......
Purchase total was a little under $19K. If I had paid the monthly payments as set in the contract, I would have paid a little under $22K and payoff would have been in October of '25. By paying about $40 extra each month, I knocked it down to where I could make a few bulk payments (Stimulus Checks, sold items, etc.) and bring it down to where I could pay it off a full three years early with a total amount paid of a little over $20K saving around $1,300 in interest.
   / What did you do on or to your LS Tractor today? #2,324
Ahhhhhh ......
Well, I think congrats are in order!
   / What did you do on or to your LS Tractor today? #2,325
So I got my MT573 a little over a month ago. I have been too busy working on my house to do anything with it.
A local guy came by this weekend to pickup all my old scrap from the remodel. I had an old heat pump that weighed maybe 400-450lbs. I have a set of those clamp on forks for moving small stuff around that I have been using with my JD. I knew the JD would not pick up the heat pump so I put the forks on the new LS to pickup the heat pump to put on the scrappers truck.
When I lifted the heat pump the bucket bowed out of shape. I was a little surprised since I never had the JD do that. I ended up strapping heat pump and lifting it that way to load it.
The bucket did go back almost to it's original flat shape on the blade edge.
   / What did you do on or to your LS Tractor today? #2,326
Congrats, Diggin, well done
   / What did you do on or to your LS Tractor today? #2,327
TimberFarm, maybe add a reinforcement to your bucket?
   / What did you do on or to your LS Tractor today? #2,328
I was thinking of buying that Extreme edge from Everything Attachements. That should stiffen the bucket edge up. A little pricey at $664, but the alternative is an aftermarket bucket that is heavy duty.
   / What did you do on or to your LS Tractor today? #2,329
TimberFarm. I bent mine in clay. I bent it back and put a wicked edge on. For sure worth the few hundred bucks. I would recommend you ask them to make the side tabs longer or lower. Mine ended up on the corner of a welded on strengthening plate.
   / What did you do on or to your LS Tractor today? #2,330
Thanks for that tip.
I will have to take a close look at mine.
(APPROX. 20) 4' X...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
