What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #2,321
Looking great
Ahhhhhh ......
Purchase total was a little under $19K. If I had paid the monthly payments as set in the contract, I would have paid a little under $22K and payoff would have been in October of '25. By paying about $40 extra each month, I knocked it down to where I could make a few bulk payments (Stimulus Checks, sold items, etc.) and bring it down to where I could pay it off a full three years early with a total amount paid of a little over $20K saving around $1,300 in interest.
   / What did you do on or to your LS Tractor today? #2,324
Ahhhhhh ......
Well, I think congrats are in order!
   / What did you do on or to your LS Tractor today? #2,325
So I got my MT573 a little over a month ago. I have been too busy working on my house to do anything with it.
A local guy came by this weekend to pickup all my old scrap from the remodel. I had an old heat pump that weighed maybe 400-450lbs. I have a set of those clamp on forks for moving small stuff around that I have been using with my JD. I knew the JD would not pick up the heat pump so I put the forks on the new LS to pickup the heat pump to put on the scrappers truck.
When I lifted the heat pump the bucket bowed out of shape. I was a little surprised since I never had the JD do that. I ended up strapping heat pump and lifting it that way to load it.
The bucket did go back almost to it's original flat shape on the blade edge.
   / What did you do on or to your LS Tractor today? #2,326
Congrats, Diggin, well done
   / What did you do on or to your LS Tractor today? #2,327
TimberFarm, maybe add a reinforcement to your bucket?
   / What did you do on or to your LS Tractor today? #2,328
I was thinking of buying that Extreme edge from Everything Attachements. That should stiffen the bucket edge up. A little pricey at $664, but the alternative is an aftermarket bucket that is heavy duty.
   / What did you do on or to your LS Tractor today? #2,329
TimberFarm. I bent mine in clay. I bent it back and put a wicked edge on. For sure worth the few hundred bucks. I would recommend you ask them to make the side tabs longer or lower. Mine ended up on the corner of a welded on strengthening plate.
   / What did you do on or to your LS Tractor today? #2,330
Thanks for that tip.
I will have to take a close look at mine.
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
UNUSED FUTURE FM57 - 57" HYD FLAIL MOWER (A52706)
UNUSED FUTURE FM57...
1997 FORD F-350 XL FLATBED TRUCK (A52706)
1997 FORD F-350 XL...
2017 Autocar Xpeditor T/A New Way 31Yd Side Loader Garbage Truck (A55852)
2017 Autocar...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
