What did you buy this week?
   / What did you buy this week? #3,141
Do you get a rebate or tax credit to help with the high initial cost of installation?
There is a federal tax credit. Some electric companies give a rebate, I need to call my utility this week to see what they do, if anything.
   / What did you buy this week? #3,142
With my propane dealer charging me just over $4.50/gal for propane, I bought/installed a heat pump water heater. Which is 4x as efficient as the propane one. Time will tell how it works out.
Right now prices range from $1.59 to $4.13 from local suppliers according to current FakeBook posts in Lititz PA. We buried a 1,000 gallon LP tank a dozen years ago and Wifey watches for low prices. One time not long after burying the tank she had it filled for just under a buck a gallon. Before having our own tank, we couldn't shop and had to pay whatever the supplier was charging. We have around 2,700SF two story that we now heat for roughly $500 per year.
I did have a hybrid WH (GE Geospring) for a while. I LOVED it while it worked. It heated water inexpensively and dehumidified the basement at the same time. It was, however, problematic and eventually we ran it on resistance heat only after multiple compressor fails. My boss also had two of these. He had one with a red top and another with a black top like ours. He said the red top WH was trouble from the beginning and the black top lasted longer.
For our next WH I'd prefer another hybrid - but only after one of them has a great track record.
   / What did you buy this week? #3,143
I had a stand alone hot water heat pump. A relay failed and cooked the unit after only a couple years. The company wouldn't do anything, I abandoned it.
   / What did you buy this week? #3,144
I have a buried 500 gallon tank that my gas supplier says they own, it was put in by the previous owner. If I can save one tank of propane, the unit has paid for itself. I got a Rheem unit which seems to be highly rated. Earlier units were problematic and who repairs them?? Plumbers won't touch them as it has a refrigeration system in them. HVAC techs won't touch them as they don't know anything about them, and they are a plumbing system. I am not looking forward to the day it goes belly up. The Europeans have been using them for years, they should be reliable.
   / What did you buy this week? #3,145
I used to get so many service calls on heat pump water heaters i never wanted one. As for propane, why is yours so high. Ours is less that $1.25 per gal here
   / What did you buy this week? #3,146
I just wanted one as for backup if my other hydraulic top link fails... (it's had a rough life so far :eek:).
   / What did you buy this week? #3,147
My neighbor is paying $2.50/gal from the same company. I need to use at least 250 gal/year to get their volume discounts and I only use about 100gal/year since the heat pump heat/AC was fixed. It uses propane as the backup heating and before the unit was fixed, it would fire up the propane heat when the outside temp was as high as 43dF. Since the unit was fixed, it doesn't kick in the propane until OAT gets down to about 27dF.
   / What did you buy this week? #3,149
Ordered a Milwaukee 3/4-inch impact at 20% off the going rate, then got a free stubby 3/8-inch impact when ordering two batteries for the first one.
   / What did you buy this week? #3,150
Ordered an 18volt Ryobi inverter. Takes 8 18 volt batteries, output 1800 watts. We shall see.
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
Carolina 30-Ton Capacity Shop Press w/Pittsburg 20-Ton Jack, Model CP100, S/N 04020 (A59076)
Carolina 30-Ton...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2014 Dodge Charger Passenger Car, VIN # 2C3CDXAT8EH223963 (A57453)
2014 Dodge Charger...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
