LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,180
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Not a lot to tell about; It's a mobility scooter XL-4L, haven't even been able to find a brand name. There are numerous one's with the same or similar model and spec's. I bought this one used.
As far as the "specs" for it,
it is a 60V drive system, with 5 20h 12V batteries wired in series.
either an 800 or 1000 watt motor depending on who you read,
front and rear drum brakes,
supposedly a 500 pound load capacity, (fortunately I'm quite a bit shy of that)
a so called 3 speed, which is actually just a voltage limiter to the motor, makes first speed almost useless unless on a flat level hard surface,
supposedly 15 mph topped out,
3.00-10 pneumatic tires (so hopefully good traction),
should climb a 20 degree grade (I'd be surprised),
weights close to 300 pounds (280),
I've already remove the wheely bar wheels, and had to access and change a bit of the battery wiring.
It worked when I checked it out and loaded on the trailer to bring home, when I got home it was completely dead. I had noticed it bounced pretty good in a couple of spots, it pulled the main battery feed off the battery terminal that goes to the main breaker (1/4" tabs on the battery) removed there wire and added a new longer wire and up and working.
We will see how it ends up working out, or if I end up getting rid of it.
Then the royal pain is transporting it;
A trailer is likely the easiest way to load and haul,
but often parking is a bit limited and a trailer makes that more difficult.
I bought a hitch mounted carrier.
Got it put together and mounted to my pickups hitch (what a cluster f--k)
It hits the tailgate before it's all the way down, would put a hell of a crease in that.
Then the ramp doesn't even reach the ground. My pickup is a 1500 RAM with no lift kit or anything.
So I've got a 4" dropped receiver extension, hopefully that will lower it enough to use the tailgate but not be so low it drags at times.
The carrier came with a license plate relocator bracket, hopefully the po-po don't fuss to much about the plate being obstructed. It would be a royal pain to have to switch the plates around when using the carrier.
I've ordered new button head bolts ( a bit longer also) and better nylok nuts, the button heads are to get the sharp headed hex bolts away from the tires sidewall.
