What did you buy this week?
   / What did you buy this week? #2,411
Not a lot to tell about; It's a mobility scooter XL-4L, haven't even been able to find a brand name. There are numerous one's with the same or similar model and spec's. I bought this one used.
As far as the "specs" for it,
it is a 60V drive system, with 5 20h 12V batteries wired in series.
either an 800 or 1000 watt motor depending on who you read,
front and rear drum brakes,
supposedly a 500 pound load capacity, (fortunately I'm quite a bit shy of that)
a so called 3 speed, which is actually just a voltage limiter to the motor, makes first speed almost useless unless on a flat level hard surface,
supposedly 15 mph topped out,
3.00-10 pneumatic tires (so hopefully good traction),
should climb a 20 degree grade (I'd be surprised),
weights close to 300 pounds (280),
I've already remove the wheely bar wheels, and had to access and change a bit of the battery wiring.
It worked when I checked it out and loaded on the trailer to bring home, when I got home it was completely dead. I had noticed it bounced pretty good in a couple of spots, it pulled the main battery feed off the battery terminal that goes to the main breaker (1/4" tabs on the battery) removed there wire and added a new longer wire and up and working.
We will see how it ends up working out, or if I end up getting rid of it.
Then the royal pain is transporting it;
A trailer is likely the easiest way to load and haul,
but often parking is a bit limited and a trailer makes that more difficult.
I bought a hitch mounted carrier.
Got it put together and mounted to my pickups hitch (what a cluster f--k)
It hits the tailgate before it's all the way down, would put a hell of a crease in that.
Then the ramp doesn't even reach the ground. My pickup is a 1500 RAM with no lift kit or anything.
So I've got a 4" dropped receiver extension, hopefully that will lower it enough to use the tailgate but not be so low it drags at times.
The carrier came with a license plate relocator bracket, hopefully the po-po don't fuss to much about the plate being obstructed. It would be a royal pain to have to switch the plates around when using the carrier.
I've ordered new button head bolts ( a bit longer also) and better nylok nuts, the button heads are to get the sharp headed hex bolts away from the tires sidewall.
   / What did you buy this week? #2,412
Sounds like a real PIA. Maybe a used lift gate for the pickup is a better way to go?
   / What did you buy this week? #2,413
You need Iron Man's exoskeleton suit.
   / What did you buy this week? #2,414
4 new tires for the wife's 2020 Outback.
Friday I called the Tire Rack, paid for the tires over the phone, drove in there Saturday morning, had them installed, and drove out $6 shy of $1000.
Wife and I had a conversation regarding how back when we were first married, we'd have to talk about and save up for a set of 4 tires for $250 and get nervous about having to spend that much. Now we don't think about stuff like that. We're fortunate. (y)
   / What did you buy this week? #2,415
Or a crane. My Ex-GF had a swinging crane mounted in her van for her mom. It was 12v powered and could lift an electric scooter then swing it into the van. This was a full size Ford van though.
The crane I have on my milling machine came from HF. It swings too but it's a manual crank and jack for the lift. I bet a 12v wench could be adapted to it. I cut about a foot out of vertical post so I could get it under the roof.
   / What did you buy this week? #2,416
That's about what I have in my new 20" mag wheels. The tires were cheaper at $185 each. There are custom mag wheels that can approach $10k EACH. I'm glad I'm not that invested in my old truck's looks. :oops:
   / What did you buy this week? #2,417
The way I think about it, good tires are a great investment in our health and safety. Shorter stopping distance, better traction, better handling in emergency situations. Totally worth paying $1k/4 years or so.
   / What did you buy this week? #2,418
Aquatic weed killer. Trying to get the pond somewhat usable. Water levels are down and I figured this was a good time to spray. Weedtrine-D I think is the name. Also got a two gal sprayer
   / What did you buy this week? #2,419
If you have fish, be careful in how much of the pond weed you try to kill
at one time. Decaying organic material.....you don't want to cause a
fish kill.
   / What did you buy this week? #2,420
That is an area we agree on, Lost a BIL due to worn tires. I will spend the money on them and mount and balance myself which over time offsets some of the new tire cost.
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
RIGID POWER DRIVE/HAND HELD THREADER (A53843)
RIGID POWER...
2014 FONTAINE TRAILER CO. STEPDECK (A53843)
2014 FONTAINE...
2014 FREIGHTLINER CASCADIA SLEEPER (A54313)
2014 FREIGHTLINER...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53473)
PENDING SELLER...
