What did you buy this week?
   / What did you buy this week? #2,011
My Emglo compressor wasn't building up above 80 PSI - so took head off and found one reed valve broken - some pits in the cylinder head but walls were fine.
ZFZMZ Replace Reed Valve Valves STAINLESS Fits Compressor (2 pack) for $7.99
Runs like a champ now with new oil, pressure switch and 8$ for reed valves!
   / What did you buy this week? #2,012
I sold my Fords and bought this. View attachment 3338661
I think you will really like the Cummins
At the height of our horse hauling years we logged 200k miles a yr. I remember a '04 dodge cummings going through a fuel rail every 30k miles. Dodge blamed it on low sulfur fuel.
My 03 5.9 Cummins is closing in on 200K miles.
Still on stock fuel pump, injection pump, injectors and even brakes and shocks, the brake re do is in the que now.
Has needed a clutch slave hydraulic cylinder, turn signal switch, water pump 2 front axle U joints (family member left it in 4x4 on paved roads hauling a fully loaded 10K trailer) and a Dash cover, oil and filters.
It also gets the best MPG by far of everything we have other than the street bike and EV.
From reports the Newest Ford HD diesels are getting the best MPG -better than Cummins or the Duramax.
I would not own any CP4 injected diesel without a very long warranty.
   / What did you buy this week? #2,013
Still on stock fuel pump, injection pump, and injectors.
I stand corrected. It was the 02 that ate fuel rails. Replaced by an 04 that was no problems.
   / What did you buy this week? #2,014
I was getting annoyed having to haul a skid steer back to the shop every time to unload something so I bought this.
   / What did you buy this week? #2,015
   / What did you buy this week? #2,016
Now we're talkin.
I operated 3 different units over the years that had spreader forks. They are so-much more capable.
I’d like to find a junk one with spreader forks and build some spread forks for the skid steer.
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A58018)
2016 FORD F-550...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2019 CATERPILLAR 259D SKID STEER (A52709)
2019 CATERPILLAR...
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
