What did you buy this week?
   / What did you buy this week? #721
35gallon tank from Tractor Supply.
Tractor Supply normally lists them for $199.00, but was able to get 10% off after asking the store manager why the 35ga was the same price as the 45ga sitting next to it. Short of driving over to the Norwesco facility an hour and half away and buying direct this is the best price I've found, inclusive of shopping online.
I planted 7 blackberries and 4 blueberry bushes recently and the FEL watering pallet (50 gallon drum mounted sideways) is both wearing out from sun damage and is bit overmatched for comfortably safe use on my Bx. The 35 gallon mounted on a custom pallet will fit on a shelf in my shop and be a lot safer to utilize.
   / What did you buy this week? #722
2 apple trees, will plant today.
My Echo 620p started right up this morning, canned gas, sitting a few month.
   / What did you buy this week? #724
I picked up an old(ish) 5 foot rotary cutter (aka bush hog) for $200. Got it identified with help from this forum. Not rusted out - one slice in the rear from a blade. The seller said it leaks at the base of the gearbox. PTO shield is missing. It needs a vented fill plug to relieve the pressure when hot (I think that's all). I'll touch up the blades and make sure the attaching bolts/nuts are good. I replaced the grade 5 bolt with a grade 2, for the sheer bolt. May have to cut the PTO shaft. Haven't hooked it up to the tractor yet...
Hooked it up today and tested it out. Vented fill plug fixed the "leaks oil when hot", and it cut great.
   / What did you buy this week? #727
4 pounds of Amdro Pro. The fire ants are kicking my ass this year.
   / What did you buy this week? #728
A bushel of buckwheat ($ 35), and $ 60 worth of stuff at a garage sale (jig saw, corner sander, axe, 4 ft level, (3) pair of shoes, (3) pair of sox, leather belt, fancy wool Orvis fishing hat, camo hunting hat).
   / What did you buy this week? #729
Curious what this set you back? It looks built well.
Right at $405 plus taxes. Outfit is Buckeye Power Sales. Sales person I interfaced with is Jason and they treated me exceptionally well. I highly recommend them.
   / What did you buy this week? #730
Needed a carb kit for my 170 Stihl chainsaw.
Stihl still ( :rolleyes: ) in good shape otherwise.
Parts guy said the saws are discontinued and showed me the replacement. I didn't like it so I bought one of their last old stock 170s.
I really like them for their balance and decent power for what you're paying for.
I don't use it for cutting huge piles of firewood but for trimming and light work.
For me, the perfect saw in that range.
My old one is aboot 18 years old and other than I suspect needing a diaphragm replacement it still runs strong.
Gives me something to fiddle with while I cut with the new one.
$240 +tax, plus threw in a 6 pack of mix and an extra chain.
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A56435)
2012 Ford F-150...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2019 Kubota RTV-X1140 4x4 Diesel Utility Cart (A56857)
2019 Kubota...
