What did you buy this week?
   / What did you buy this week? #61
Now that is what I call a well spent week. Most of my lathe tools are carbide now. Much better for metal - though I'm not sure that HSS isn't better for wood and plastic.
rScotty
Just getting into and learning "machining" and
added a BXA ? 250-200 series tool post and 11 holders with some XL's added a few weeks back.
Finding, When folks say to budget 1/2 or more for tooling -it isn't a joke, but does help you can find it used at a good price.
After adding the DRO to the lathe it has occurred to me that they would have been even handier and needed on the 1/2 knee mill, so that is next on the list but looks like everyone is now going to blue tooth and a tablet with scale adapter card. More research needed there.
Please tell me that Machining cannot turn into an addiction :)
   / What did you buy this week? #62
Ha, well, had you not said something, I may have found out about it too late. So, "feedback is a gift" my boss always says. I'm happy with the Tundra, it may take another week or so for my wallet to stop paining me in the @$$.
The conversation with the Tundra salesman, and my insurance lady were humbling to say the least LOL.
Frankly, the 5.0L Cummins was never very good. RAM was wanting a smaller diesel to offer in their 1500 series trucks, and because of the long standing relationship in the HD trucks, Cummins offered them the 5.0L V8 diesel. RAM tested the engine and ultimately turned it down. Their analysis is ultimately correct, completely not regarding any reliability problems the engine has: for the size and weight and number of cylinders, the 5.0L Cummins doesn't make very much horsepower and torque...but also doesn't get very good fuel economy either. RAM ultimately went with the smaller, cheaper - and possibly equally unrealiable - VM Motori Italian-made 3.0L V6 EcoDiesel, which was even less powerful but did achieve very good mpg. (As a side note - the 3rd generation of this engine seems to be reasonably reliable, but RAM is discontinuing it).
One of the issues in the 5.0L Cummins is the Bosch CP4 high pressure fuel pump. Ford and GM used it from 2011-2016 and had numerous fuel system failures with it due to "diesel contamination" causing inadequate pump lubrication. Once the pump began to fail, it would send metal shrapnel throughout the entire fuel system, including the injectors, lines, fuel heater / cooler, water separator, lift pump, and filters. Typically on a Ford 6.7L or GM 6.6L diesel, the dealer replacement cost of the fuel system could be $10k or more. And since the failures always seemed to be caused by "fuel contamination," most of the time warranty wouldn't pay. Starting in 2017, GM ceased using the CP4 and began using a Japanese Denso fuel system, which seems to have a reasonably good track record (however, high pressure pump failures have occurred in these as well, just seemingly much less frequently). Ford made some modifications to the pump, including a hard slippery coating on pump pistons to help provide lube in the event of diesel contamination. Since 2017, Ford 6.7L engines with the CP4 pump have continued to fail, but seemingly at a far lesser rate than previously.
Up until 2019, the RAM HD trucks with the 6.7L Cummins engine continued to use the very well proven and reliable Bosch CP3 high pressure pump. However, for the 2019 models the engine was updated and began inexplicably using the problematic CP4 pump. The problems were so numerous that RAM/ Cummins modified the pump after just one year, and completely discontinued using it after the 2020 model year; reverting back to a modified version of the CP3 pump. There is a major recall on CP4 pumps on RAM vehicles, and this includes the EcoDiesel which also uses this pump (However, with less fuel volume demand the CP4 failures in the EcoDiesel seem much less).
Of course Cummins used this pump on the 5.0L engine as well, and suffered all the same problems as everyone else. Unfortunately the 5.0L engine is also not super easy to work on, and to compound the problem - Nissan mechanics are not diesel mechanics in this country and really had no experience. Some very frustrated owners had their broken down Titan Cummins trucks towed to heavy truck repair facilities which have tons of experience working on Cummins engines. However, very few were willing to work on this 5.0L engine. The 6.7L in the RAM HD trucks was familiar territory, having been used in school buses, large straight trucks, delivery vehicles, etc...but not the 5.0L.
Anyway, long post, but ultimately I think you made the right decision. I prefer domestic pickups, because I don't buy into the "Japanese magical reliability" mantra one bit, but I think your new Tundra will serve you very well. The Tundra is powerful and has an exceptionally large rear axle for being a half ton. Likely larger than what was in the Titan XD. And even though Nissan marketed the XD as being a "heavy duty half ton," even when they introduced it there were already Ford F-150's that could tow over 13,000lbs which is more than the diesel Titan was rated for.
   / What did you buy this week? #63
You just bought the wrong diesel.
Give it another try and look for the Cummins or Duramax badge next time.
Or Powerstroke, so long as its an antique 7.3L or a modern 6.7L.
   / What did you buy this week? #64
Just ordered a 25 pound box of wrapped peppermints from my favorite candy company in Napoleon Ohio.
What is name of said company? I'm no too far from Napoleon, O.
   / What did you buy this week? #65
Well - after only two and a half years - MR Coffee gave up. Had to buy something new. Got a percolator coffee maker. Works just fine on the kitchen stove.
   / What did you buy this week? #66
I think that is a good choice. A lot of Ford fans foofoo the the Cummins because they know it’s better. But having been in the infrastructure business over 40 years I have never seen a major manufacturer of heavy equipment or pumps and generators that use Ford or GM engines except during the two stroke days.
I bought 35 new hydraulic hoses and eight cylinder kits for my 32 year old JCB 1550b backhoe. I retired from working for others 18 years ago and the hoses are showing a lot of cracks and some cylinders are leaking I have put most of them on and will finish after I get done with firewood.
   / What did you buy this week? #67
US Military used GM 6.5L diesel engines in the Humvees the entire time (not a great choice, admittedly). Current Oshkosh JLTV (Humvee replacement) uses a 6.6L Duramax. "The Beast" presidential limo uses a Duramax. The Secret Service has an armored heavy box truck in every motorcade which handles all comms and logistics and can jam signals...Ford 6.7L powered truck.
I've been around diesels for awhile now. Cummins is still very good, but far from perfect. It seems Ford and GM have both improved their V8 diesels a lot while Cummins has perhaps slightly declined in quality and reliability. A million mile Duramax or Powerstroke nowadays is as common as a million mile Cummins. And the V8 diesels are putting out more power and torque.
   / What did you buy this week? #68
I "thought" I also needed a diesel pickup. So I bought a used Chevy 6.5L turbo diesel with only 118K miles on it. It turned out to be a real dog and a money-pit. Best days of my life were like buying a boat, i.e. the day I bought it and the day I sold it.
Lesson Learned: I didn't need a diesel to pull my little utility tractor on a trailer.
Well you picked the wrong diesel for sure. Had a couple of those. Weak and overheat if you try and tow a hitch let along something attached to it.
   / What did you buy this week? #69
One thing I do know and that is, I've bought my LAST UAW made car. Next one will be either a Honda or a Subaru, most likely a Subrau Forrester or Outback.
Than expect to be doing headgaskets.
   / What did you buy this week? #70
Picked up a 66 Fairlane convertible last week. Had it shipped from PA to Texas.
Reliving my teenage years. Had a GT as my very first car.
1996 CASE 590SL Backhoe (A59213)
1996 CASE 590SL...
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2025 AGT MX12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MX12RX...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Mini Skid-Steer Concrete Mixing Bucket (New/Unused) (A59225)
Mini Skid-Steer...
