What did you buy this week?
   / What did you buy this week? #2,581
6" because you are going to park Tanks on it?
PT because you are going to leave the wood in place?
Well, 6" is the standard for anything that gets vehicles on it. Yes, sidewalk does "generally" hold up to passenger vehicles; but if you see any area where people frequently park/drive over, 4" is generally cracked up.
PT, cause its $10.40/each; vs $8.15/each not PT; and no, definitely not leaving in place. Figure, I need to reuse these for the next two pours, and whatever afterwards; not worth the trouble of saving $12
   / What did you buy this week? #2,582
That's all good.
I'm saying I've poured a miles of 4" drives and parking pads, garages that are still good 50 yrs later. Talk to your batch plant to get 3k psi mud and insert wire or add fiber.
I'm not judging. I'm just saying it's not necessary.
   / What did you buy this week? #2,584
I bought or should I say my extended warranty is buying a new passenger side exhaust manifold for my 2019 Dodge Ram. I bought the after market warranty that my credit union offered, way cheaper that the dealer. They wouldn't do both sides.
   / What did you buy this week? #2,585
That's all good.
Everything work related, that takes traffic, 6", 3000 psi, no wire/fiber; actually Travel lanes are 8" and have rebar mat.
Ive also demo'd a lot of concrete, and 4" sidewalk, once you get a side up, breaks pretty easily with a 8# sledge; 6" without wire takes some beating with a back hoe bucket; 6" with wire; takes a Lot of beating... With rebar mat, time to call a specially concrete cutting sub
   / What did you buy this week? #2,586
High strength concrete, with wire/fiber is a necessity. BUT so is, a proper base. Put that on quicksand and you will have gravel before you know it.
I have a brother-in-law that does precast for the state (NJ and PA, maybe DE) , and two nephews that do pour-in-place for Amazon and the like. Proper prep is 100% key.
   / What did you buy this week? #2,587
Not to go too far down the concrete rabbit hole, But; Many people who pour concrete dont actually understand/care how it actually works. You take a normal 3000 psi, standard rock concrete, designed to be poured at a 5" slump; dump 40 gal of water to get it to an 8" slump; and i really think a lot of folks dont understand the affect that has. Not to mention, id rather pull stiff mud down hill, than wet mud Up hill....
Yes, there are mixes designed to be poured at a 9-10" slump, like drilled shaft mud, but its Designed that way;
Yes, you can chase some water out of a form with the concrete, with minor effects; but there are absolutely guys that will dump into a 20" thick edge, that has 20" of water in it...
As pointed out, 4" of Good concrete, over compacted, 95% density, suitable material, is better than 6" of wet crap, over muck ... With that, any official design I've ever seen that involves traffic loads, its 6".
   / What did you buy this week? #2,588
We used to pour 3k psi building slabs and 2.5k psi flatwork on the same day. All the truck tickets came to me when the pours were done. The slab guy handed me a stack of tickets and I these can't be yours. He insisted they were. Well, I said you poured 2500 psi mud in that slab. 30 days passed and the cylinder break tests read 2600 psi. We waited another month and the test came up to 3200 psi. Conc keeps getting harder with age....
   / What did you buy this week? #2,589
So, I have Often seen 3000# mix break at 28 days at 3,800-4300. They absolutely include a safety factor. We also had an incident once with 3000# mix, that broke before a readable number... just crumbled. That was on a 3 story student housing building; and was a major ordeal. Luckily we had a testing guy, that recorded any water added; pulled slump, air, and 7/14/28/hold cylinders.
If I remember right, (I was just an assistant super on this job), the concrete company's starting offer was price of the concrete, what a joke; i believe they ended up paying for the demo, and the 1st bad batches; but i think we ate all the form/pour labor
   / What did you buy this week? #2,590
Sub grade also makes a difference. A sandy, or silty clay sub grade with a higher water table will require a thicker pavement section than building in a rocky, west coast area.
That's why fed projects out west can build concrete highways with a lower sack count out west, and why they have been proven not to work in the middle Atlantic/Southern coastal States.
Mini-Excavator Forks (New/Unused) (A59225)
Mini-Excavator...
2006 CHEVROLET EXPRESS SERVICE VAN (A58017)
2006 CHEVROLET...
New/Unused CFG Industrial H12R Mini Excavator (A57453)
New/Unused CFG...
BLANTON 12' DRAG HARROW (A52708)
BLANTON 12' DRAG...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
Mini Skid-Steer Hydraulic Skeleton Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
