What did we fry?
/ What did we fry? #1
gerry100
Troy Built 16 Hydro ( built by Bolens I think), about 10-11 years old.
Have had a problem with the clutch for the mower deck reengaing after you turn the deck off, likely the potted circuit module.we've been living with that.
Old battery I've been too busy to replace, so we charge it in the tractor every time we try to start it after it sits for more than 4-5 days.
Yesterday , my wife ( yes it really was her) hooked up the charger backwards ( wrong leads on wrong poles).
When we try to crank it, it sounds like the starter is spinning but not engaging the motor - not sure that's it but that' s what it sounds like.
Tried charging the right way, but she says the sound is the same.
Afraid we did some electrical damage and would like to try to fix it myself.
Guidance appreciated.
/ What did we fry? #2
It doesn't seem reasonabe that charging the battery backwards would harm the starter. Maybe the battery is shot and has just enough voltage to spin the starter but not engage the bendix. I'd start by checking the battery voltage with the starter engaged. If it's not up around 10v or better you'll have to change the battery before going any further.
/ What did we fry? #3
I just had another thought.......I don't know if reversing the charging cables could possibly reverse the polarity of the battery. Some DC motors' direction can be reversed by reversing the polarity. If this is the situation, the bendix won't engage backwards.
/ What did we fry?
Gene,
Before the reverse charge incident the dead battery acted as you would expect. a click or partial turn with no start.
If your second post is correct I'll replace the battery, overdue anyway and give it a try.
Thanks for the idea.
/ What did we fry? #5
The polarity reversal might have destroyed the solenoid or windings that allow the starter gear to move outward and engage to the flywheel. (Called the Bendix or Bendix action.) This electrical component is most often located within the starter motor itself, but is separate from the actual motor windings that spin the starter.
-Fordlords-
/ What did we fry?
I think we dodged that one.
After hooking the battery up to the charger the right way for a while , I actually got it started.
We'll try a start and run today.
/ What did we fry? #7
Sounds like you are never really charging the battery to capacity. My neighbor does that, puts the charger on a few hours before he plans to use it, then uses it for a hour and parks it again. Never really charging the battery fully. He complains his battery is always dead every few weeks but sees nothing wrong with his charging methods. He is afraid his garage will burn down if he lets the charger on for too long. Also, he bought the cheapest charger they had at WM.
You need to get a Battery Tender, you can leave them connected all the time, They work automatically to keep battery up.
/ What did we fry? #8
I would use a good accurate volt meter to check the tractor's charging system. With the engine running, there should be around 14 volts at the battery and it should get fully charged up running the tractor after a half hour or so. If that is OK, I would buy a new battery rather than risk continuously charging an old one that is not properly holding a charge- those are the ones that tend to explode and cause the fires if unattended.
-Foordlords-
/ What did we fry?
Well , since we charged the battery in the right direction for a sufficient time the motor turns fine but will not fire. Seems like no spark.
My guess would be that the magneto stopped working?
What is confusing is that it did fire up briefly a few days ago.
The only fuse is good and I cleaned the plug ( which was fouled).
Still no start.
Inputs appreciated.
/ What did we fry? #10
A new plug would be my next move. and then check the flywheel key if still no run.
/ What did we fry?
New plug not a problem but what is a Flywheel key and how do I get at it?
/ What did we fry? #12
You will have to remove the engine cover from over the flywheel.
The flywheel key locks the flywheel in place on the crankshaft. The flywheel will have to be removed, but usually not just to check. Just remove the nut and washer that holds it on, then look closely you should see a square groove in the flywheel where it slips on over the crankshaft, if you are lucky you can see the matching groove in the crankshaft. They should be perfectly aligned, if not remove the flywhell with an appropriate puller and replace the key that fits in the 2 slots and keeps the flywheel in time with the crankshaft.
/ What did we fry? #13
Since you didn't even turn the engine over with the battery reversed, I don't think you did anything with the flywheel key. That happens more on push mowers than riding mowers anyhow. The flywheel key is a shear key that breaks to protect the crankshaft when you hit an immovable object with the blade.
I think your problem is the ignition "kill" wire. The ignition or some other safety switch will ground that wire just the same as if you turned the key off. You can normally just unplug the wire and the engine will start. If it does start, then you have to troubleshoot the safety switches to find out which one is causing the problem. Two that are most suspect are the reverse kill switch and the operator present switch under the seat. The reverse kill switch will kill the engine if you have the blades engaged and put the mower in reverse. I normally defeat that switch on all my riding mowers. The operator present switch will not allow the mower to start if you are not sitting on the seat.
/ What did we fry?
While tinkering I noticed that the plug that I cleaned was still dry after a long try at starting and that the fuel filter was also dry.
The fuel pump is on the side of the engine and I assume is mechanical. Since the engine never ran in reverse, I don't think that is damaged.
But there is something called a fuel solenoid there somewhere.
Could this solenoid be messed up or stuck due to the reverse charge and subsequent start attempt?
Inputs appreciated as always.
/ What did we fry? #15
Is there an actual spark at the plug gap when its pulled out of the engine and checked while cranking?
I don't know what make/model engine you have, but many small engines, even ones 10-12 years old have electronic capacitor discharge ignition modules that can be destroyed by polarity reversal. In that case there will be no spark at all, and the module has to be replaced. The voltage regulator/rectifier and/or alternator stator can also be damaged, which you might discover after getting the engine running that it will not charge the battery at all. The fuel shutoff solenoid is also a DC component, but I tried polarity reversal on an old one I had in the shop and it was not damaged. Not trying to scare you, just throwing out some ideas.
The easiest way to distinguish between fuel or ignition no-start problems is to spray a little gumout or starting fluid down the air intake and try to start it. If the ignition is OK, the engine will usually start and run for a few seconds and stop, this indicating a fuel delivery problem. If it does not start at all, it's often ignition system at fault.
-Fordlords-
/ What did we fry?
Good stuff.
I'll look at the wiring chart, but the only solid state looking module is a box with wires going into it filled with potting compound - I asume all the components would be in there.
I'll also try the gumout test and let you know.
/ What did we fry?
Engine will run for a few seconds on starter fluid. I pulled the fuel solenoid and it's working.
Problem seems to be no fuel getting form the tank thru the fuel pump to the carb bowl.
Guess I'll check the fuel lines an dth epump.
Is it possible/necessary to prime the fuel pump?.
/ What did we fry?
After checking the fuel lines and the filter, I primed it by pouring gas into the line before the pump.
Started right up and ran until the tank ran dry, A few minutes.
I think the fuel tank was too low to prime the fuel sysyte,m and draw gas.
I know there wa sgas in thew tank when I checked testerday.
Murphy likes you to spend hours on something beofre you stumble on something that is ,in retrospect, obvious.
Tanks for trying to help.
/ What did we fry? #19
No problem :) I ran into this same stumper a few months back when my 682 was running rough and backfiring, yet it looked like there was still gas in the tank. Finally after fussing with everything I could fuss with I topped the tank up with gas and it was fine. I almost always panic before I stop to think about the easy stuff, someone told me that is a trait of the mechanical type of mind :)
-Fordlords-
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
Knight Verti-Maxx 5032 Feed Mixer Wagon (A66408)
Knight Verti-Maxx...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
APPROX 500bu FEED BIN (A64277)
APPROX 500bu FEED...
1986 Ford 7710 Tractor (A66285)
1986 Ford 7710...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
