What could i use this for?
   / What could i use this for? #22
I had heard about the glyphosate and metal issue, but I thought it was just that the glyphosate would corrode the metal. "Explosive gas" sounds a little more exciting that what I want to deal with.
Anyone have any good ideas what to do with a good old propane tank with two holes in the top of it that doesn't involve roundup?? :)
Yep, i built something similar. I made mine into a pressure tank for gear oil and undercoating. You could also use it for motor oil i suppose
I just have about 10ft of hose with a valve and a J shaped piece of metal fuel line on the end. I used a quick connect on the end of the hose so i could change "nozzels". Welded a 1" pipe nipple to the tank to use as a fill tube. Drilled and welded a 1/4" air fitting on the 1" pipe cap for the fill hole. I run about 30psi from my compressor to this fitting to pressurize the tank.
For undercoating, i remove the J tube, and hook up a cheap paint gun to the hose instead. I run a second air line to the gun too. Works pretty good, I can really lay the undercoating on thick.
Works great for filling rear ends. Nothing more annoying than trying to get gear oil to flow uphill from a 1L bottle.
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56436)
Case Wheels for...
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
2020 Northstar Pro Shot Pressure Washer Trailer, VIN: 4K1N1PG20LF000044, Kubota Diesel Engine, (A59076)
2020 Northstar Pro...
VINTAGE SCOTT - ATWATER 5HP OUTBOARD MOTOR (A58374)
VINTAGE SCOTT -...
LOT: (4) Pairs of Tire Chains, Fits Tire Sizes: 11R-22.5, 285/75-22.5, 295/75-22.5, 275/80-24.5, ... (A59076)
LOT: (4) Pairs of...
2015 Toyota Highlander XLE SUV (A56859)
2015 Toyota...
