What could i use this for?
/ What could i use this for? #1
Toffy
I have an air tank that is aprox. 23 inches in diameter and about 4 ft. long. This tank is of very heavy material but was taken out off service however the tank is still good for air. I have no need for another air tank but thought it might be good for a project. The only project i can think of is a lawn roller. But I don't need one. Before I throw this in the scrap pile is there anybody out there who could give me an idea what to do with this??
/ What could i use this for? #2
If I had it I would cut off one end and drill a few holes in the bottom. Fasten some chains to the end with out the end and use it to dredge ponds. PS I wish I had it as I'm looking for one to do jjust this.
Andy
/ What could i use this for? #3
Of course, as a tank you will get the full use of it...but with the cost of steel these days...
most tanks are sheet steel (put through a roller)
I've found it very easy to cut sections and flatten it out by pounding on a hard flat surface with a wooded post...works great on projects where heavier sheet metal is required...
I've used smaller tanks to add weight (filling with water) to box blades etc...
another project I made from an old tank is trash incinerator...
an opening (door) in the bottom and an elevated fire grill fastened above the top of the opening (door)...with the opening facing into the wind... this thing will burn trash/debris about 4 times faster than a ground fire...the door allows easy removal of ashes...
/ What could i use this for? #4
rain collection barrel? underground storage/root cellar for taters and other veggies? smoker/bbq grill? rodent proof storage? heat exchanger tank for solar hot water project (just add insulation and two threaded bungs)? grain storage? primary fermenter for wine/beer making? fuel storage (diesel, gas, kerosene, heating oil)? shop/barn wood stove?
those are off the top of my head. don't scrap it!
amp
/ What could i use this for? #5
amp
All excellent ideas to work with....except the heat exchanger. The tank is probabally just mild steel, which is not suitable for domestic water, old hot water heaters are a better way to go as they are galvanized or plastic.
But I really like the smoker/bbq idea:D
/ What could i use this for? #6
As /pine said, build a trash incinerator, (if your not in city limits);) I built one out of an old ( I mean WAY OLD), galvaninzed water heater, old trampoline frame for the legs, and a pc of well casing for chimney. Burns trash like no 55 gal drum will ever do. In winter I can sift out nails, tin, etc. and scatter ashes on snowbanks to help melt them down faster. Even do it on driveway concrete and it won't damage the concrete the way salt will;)
/ What could i use this for? #7
If you need a plow for your lawn tractor or 4 wheeler the curve of a tank is perfect. Take a look at "Front blade for almost free". That is what I just made mine out of, if you are creative with a welder and a little angle Iron almost free.:)
/ What could i use this for? #8
This was at one time an air tank.
/ What could i use this for? #10
Couple that tank with LBrown59's fuel transfer setup and you'd be the envy of the neighborhood.:)
/ What could i use this for? #11
Gosh I wish I had a tank like that. I'm wanting a tank I can fill with gasoline and then hook an air compressor hose to it when I need to pressurize the tank at a low pressure to force gas up thru a hose to put gas in the tractor or 4 wheeler. I'm tired of spilling gas with these cheap plastic gas jugs. I need a tank that will hold about 20 to 30 gallons and be able to handle about 5 psi of air pressure.
Pooh Bear
/ What could i use this for? #12
Cut me a piece (Band) about 6" wide that I can fab into a Stump Grinder guard! You could dice it up for a bunch of trailer fenders! Now ya got me thinking! Any one know of the "SAFE" way to cut an old 20# propane tank, to accomplish that guard? ~"Scotty"
/ What could i use this for? #13
Build a Bar-B-Que grill and enjoy. I have heard you can empty the propane tank, wash it out with water and cut it with a torch as propane don't leave any resdue only the smell which is harmless. Their not like gas tanks.
Wow Thanks for the replys. One thing I know for sure is I am caught between a incinerator or a barbecue.
It will not go to the trash!
Love this site
/ What could i use this for? #15
make a pnuematic potatoe launcher or bead seater for tires, made one used it to clean the coils on the frig. one day :D almost ended up in divorce court:eek: no sense of humor ;) best potatoe smasher in the county
/ What could i use this for? #17
That air tank is going to have a lot of rust flakes inside. I don't think it would make a very good fuel tank.
/ What could i use this for? #19
Not a good idea, as glyphosate and metal are not a good combination. Here's a quote:
"Do not expose glyphosate to galvanized metal or unlined steel tanks as explosive
gas may result."
I had heard about the glyphosate and metal issue, but I thought it was just that the glyphosate would corrode the metal. "Explosive gas" sounds a little more exciting that what I want to deal with.
Anyone have any good ideas what to do with a good old propane tank with two holes in the top of it that doesn't involve roundup?? :)
/ What could i use this for? #20
John D" We all need one of those.
LOT OF MISC BAR JOIST (A63291)
LOT OF MISC BAR...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
Caterpillar 259D3 Compact Track Loader Skid Steer (A61572)
Caterpillar 259D3...
3pt 20' Cultivator (A64119)
3pt 20' Cultivator...
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
Lot of 4 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
