What company makes a good sub-compact, gas powered, hydro, tractor.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #1
hwew
Here goes.
I am getting older and decided to sell my Everride Warrior z-turm mower and start looking for a good sub-compact, gas powered, hydro, tractor. I had a Kubota BX2200 and that would be a good fit again if it was gas powered, air cooled. Some here are probably wondering why I want to get a gas powered Sub-Compact. My health is not like it used to be and my wife and daughter will most likely take over mowing the lawn. Another reason for gas powered is just in case I'm not around to repair it. At least they can bring it someplace to get it repaired cheaper than a diesel tractor. Yes we also have lots of butchers here that claim they are diesel mechanics.
So, I am trying to find a well built gas powered sub-compact that is built tough, somewhat easy to fix, reliable, hydro powered and has 3 point hitch.
Any ideas would be helpful. I miss the old 1993 Power King but it is probably not safe for my wife and daughter. I would preferr new but used would be good also.
Please don't be hesitant with reply's.
Thank you,
   / What company makes a good sub-compact, gas powered, hydro, tractor. #2
I think your desire for a 3pt hitch forces you into the John Deere 700 series, Simplicity might have one, but a less common brand.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #3
My thought is that you should stick with diesel if maintenance is your concern. Gas engines require more attention and preventative maintenance than a diesel. Carburetors with today's fuel require fresh fuel to stay clean. Not to mention spark plugs and ignitions.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #4
I recommend DIESEL.
If all you ever do is fill it with fuel and add oil when it is low it will likely out live any gas powered tractor you can struggle to find.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #5
any real subcompact = diesel. Anything else is a garden tractor.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #6
You are prolly 6-8 years to late for a gasoline version. Even the little Kubota BX1870/1860 is diesel and it's 18hp. Bruce
   / What company makes a good sub-compact, gas powered, hydro, tractor. #7
The ethanol in today's gas creates more problems than it solves (IMHO). If you purchase an older unit that makes it that much less desirable. I have made a practice to run the gas out of all my small engines before storing them for any length of time. Diesel is going to be a better choice for less maintenance.
I understand you guy's like diesel. I also love diesels, had a New Holland 1320, Kubota B7500 and a Kubota BX2200. I am not worried about ethanol in fuel. I never had a proble with the Everride Warrior's Kawasaki engine. It's been bullitproof. Not one problem. As long as you treat the fuel and run through a tank a month nothing will happen. When it is time for winterizing just run the tank empty and drain the fuel bowl and your done. Here is the way I see it. I can repair and service pretty much any Kubota 5 series and super mini diesel from the ground up. But with my health going I will not be able to do it soon. So, since we have more butchers than diesel mechanics here it is best to stay away from diesels for my wife and daughter. Another thing is if it is time for a re-power it is less than half the price to repower a v-twin than a gas engine. I don't see a re-power happen anyway's because the Kohlar, Kawasaki and Vangaurd engines are very reliable and less maintenance than a small diesel. And I don't expect them to put on over 2700 hours like the Everride Warrior Kawasaki engine has on. That is a lot of cutting.
So, I don't want to hear about staying with a diesel. It will not happen. One option to consider is find a BX2200 that has a blown engine and repower it with a V-twin.
But if you look at the BX2200 track record when I owned one it was not very pretty. It was the worst tractor of the bunch. It was falling apart. Look at some of my very first posts. It say's it all. But for just mowing the chassis should hold up fine. I want to hear about gas powered.
Thanks,
   / What company makes a good sub-compact, gas powered, hydro, tractor. #9
Like rct427 said. JD 700 series is probably about your only option for gas and 3PH.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #10
I would recommend the x700 series with limited 3ph and rear pto. The hdap tires are very good for lawns and get good traction, same size tires as the 1000 series subcuts. I have used my x749 for lawn installation and maintenance and it does a good job filling in around the larger tractors. I would consider the gas versions with 4x4 and see if this will work for your circumstances. IIRC, the x729 is the gas version of the x749 diesel. The new models are out now so you might want to give these a look.
Here's some pics of my x749 with 3ph, everything is IMatch equipped now.
I looked at the 700's and they are nice tractors but, $10,000.00 is out of line. If I can find a good used one than I am all for it. If I can't find one than I might as well look for a Kubota bx1500 or BX2200 that has a blown engine. It would not be that hard to re-power one with an air cooled V-twin. I seen them cheap so it might be time to start looking.
I just purchased a Ingersoll 3012. It has the Vangaurd 12.5 V-twin. I comes with a snow plow and the 44" mower deck. this will be good enough for my wife and daughter. The good thing is the driveline parts will be available for some time. and it can be set up with a 3-point. It has no rear pto but it would never be used anyways. The drivetrain is bullet proof on the 3000 series and 4000 series tractors, and they are so easy to work on that most back yard mechanic would be able to maintain it. If it ever has to be repowered it is easy to do.
Thanks everyone with your reply's
   / What company makes a good sub-compact, gas powered, hydro, tractor. #13
Cub cadet branded some SCUT Mitsubishi? tractors with a 25 hp liquid Kawasaki about 10 years ago. The only one I'd ever seen the owner was looking to trade it for a diesel powered tractor. The liquid kawasakis are nice motors, but not exactly what I would want on a capable tractor. Honda also had some nice four wheel steer tractors with 3cyl inline liquid gas about 15 years ago.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #14
Neil, what you say is fact, I agree. But with all the effort needed now to meet new Tier IV norms for diesels, and the advancement of direct injection gas engines making them have more torque and better economy, I wonder if a good engine manufacturer such as Kubota would ever put out a small gas tractor. Gas tractors were plentiful for decades on farms, but then diesel came along and provided more torque, better economy, less daily maintenance, etc. But since then gas engines have come a long ways. I do wonder if there is a market for such a critter if someone were to build it. Probably EPA issues would be the first considerations whether it be diesel or gas. Or perhaps the first consideration would be if there really is any market for a gas tractor.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #15
I forgot about the Honda's, and I should not have. We just took in trade and retailed a Honda 5518 last week. It was 4wd, 4-wheel steer tractor with a Cat 0 three-point and also a front implement lift and a belly mower. It was a very smooth tractor, but this one was an 8-speed manual trans, not an HST. It had a front mount snow blower as well, which we kept as the new customer was only going to use the Honda to mow.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #16
The thing with a Diesel engine is that you can park it, say in September, then return to it in April, and it will likely fire right up. Or, even wait a couple of years.
Gas engines can be much more touchy about clogged carbs, fouled plugs, & etc.
Mom has a Diesel JD tractor and does fine with it, although she may hire people to come and help her with tractor chores. She also wouldn't buy anything other than a Diesel pickup.
Assuming you're buying the tractor new, from a reputable local dealer (not a place like HD or Lowes), then you should be able to get service through the dealer, even pickup and delivery service.
   / What company makes a good sub-compact, gas powered, hydro, tractor. #17
I have seen some with a Kohler, they may have had a Kawasaki. I think they were a 5000 series. I don't think they were very reliable machines.
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
UNUSED FUTURE 90-PLATE COMPACTOR (A60432)
UNUSED FUTURE...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
