What causes tractor rollovers?
/ What causes tractor rollovers? #101
I have a few spots on my property where I will not take the tractor - either vertical or horizontal. It might be OK but there is always the chance of a hidden hole or rock. It's just not worth finding out .............
Oh Yeah, and it can happen so fast even if you are going slow.
/ What causes tractor rollovers? #104
15 DEGREES slope and no more;
A tilt meter mounted on the center of the tractor hood or a slope meter taped on a piece of cardboard
and a no greater than 15 degree slope for sidehill mowing on a dry side hill is the one and only
thing that guaranty that you will wake up the next morning in one piece.
You have to stand at the bottom of the side hill and bring the slope meter cardboard to eye level and
then look to see what the slope is and if its above 15 degrees pass on mowing UNLESS you can mow up
and down with dry sod and someone pulling you up with a winch.
A ventrac will and can and will roll over even with dual tires so keep that in mind as it does happen.
/ What causes tractor rollovers? #105
No mention of COMMON SENSE????
Where I worked one time the foreman
said to the two new guys hope you have
some common sense and they both reached
into their pockets looking for change!!!!!!
willy
How to drive a blonde crazy put her in a
round building and tell her to sit in the corner
/ What causes tractor rollovers? #106
The main factor in tractor rollovers is tractor design above all else. Safety of cars has improved vastly over the last 50 years while tractor manufacturers just carry on turning out the same basic layout. You would want a safe car for your kids to drive but we still put up with unsafe tractors. Some tractors are safe on hills, but it is a small number.
/ What causes tractor rollovers? #107
I was using heavy equipment for paying my tuition and was driving a tractor when I was sent over to mow a steep hill near a school in the morning. Well, there was heavy dew so it was very wet and I slid down all the way to the bottom, over and over and I wonder how they managed to mow such a hill but I got it done. Well the next morning the assistant asked who had mowed that hill and when I raised my hand he went into a long "lesson" on the dangers of rollovers and how lucky I wasnt killed, and chewed out the one who sent me as he said you can never mow a hill when its wet or early morning, so my first lesson in tractoring..
Stupidity on the part of the operator.... simple answer.
/ What causes tractor rollovers? #108
Huh???
/ What causes tractor rollovers? #111
Maybe the govt could just make your tractor shut off it gets on a 12º slope. Whould you be happy then? :oops::ROFLMAO::ROFLMAO::ROFLMAO:
/ What causes tractor rollovers? #112
Driving over something that tips the tractor, something unseen, like an animal hole, makes any tilt-o-meter useless. Because that 15deg goes to 25 in a split second. I had a situation the other day. Out in the pasture, knee high grass, ran over a hole, oh how nice, who put that pos there. 40yrs earlier there was an old oak, now a decayed stump, and divot from the blow over. The memory of that is so long gone. It looks like a grassy field, the same as it has for decades. Some of this stuff catches a guy off guard, and there you go. Drive slow and deliberate, situational awareness, stay vigilant and don't let your gaurd down.
/ What causes tractor rollovers? #113
A tilt-o-meter wouldn't help if you were on flat level ground raising a bucket, load not centered with wheels turned or as mentioned sliding down a wet slope then into a dry patch or like here next to the creek is flat level pasture on one side. The problem is creek curves undercutting ground, even walking on it you can feel ground give way and creek is 10 ft. down.
I bet there are 50 ways to roll a tractor.
/ What causes tractor rollovers? #114
A couple of years ago I was mowing an area I have mowed for years with the same mower. All of a sudden i was going over. My left leg was caught under the machine. I was laying on the ground thinking oh great all I need is for this thing to catch fire. Be careful what you think in such situation because, POOF and I had fire. The battery had tipped over and out of it holding strap as the unit turned over. The positive battery post contacted the frame creating a direct short which cause the wiring to turn red hot and start melting all the plastic parts on units today. Then came the flames as I was jerking on my left leg to get it free. I got the leg free with cuts bruises and laceration. Put the fire out and turned the unit back upright. Most expensive yard mowing I have ever paid for. I could have the yard mowed for many years for what that cost me, a new mower.
Too this day I do not know what caused the unit to tip over. But it had to be operator error of some kind because I am continuing to mow the area without tipping over.
/ What causes tractor rollovers? #115
All this talk got me thinking and looking at my Kubota MX. I checked and the rears are as far out as the rear gannon (72") but the fronts are 3" in on each side. I clear a lot of fence line, some on both sides for firebreaks. I don't want my tires sticking out further than my attachments so I decided to put the 2 or 3" spacers on the front to square the footprint up.
I'm seeing lead times of 6-12 weeks. Does anybody have these in stock?
/ What causes tractor rollovers? #117
True. In addition to holes, a slightly raised area can be equally dangerous. I watched a borderline incident with a scut doing loader work recently - on a very slight grade the operator was moving too fast, with the loaded bucket too high. Rear tire went over a recently exposed large rock and it almost went over.
In this case the machine would have just tipped rather than roll.
So the "go slow and deliberate" is right on the money (and keep the bucket down low).
/ What causes tractor rollovers? #119
One thing I seem to always notice when I'm on a bit of an angle is if I look down there's a tree or a rock there and ya know.. that rops isn't going to help you if you roll onto that...
As an aside maybe the rollover type where the front wheels come up and over should be called a "flip" or something and the sideways one a "roll" to distinguish the two types..
/ What causes tractor rollovers? #120
Center of gravity height of the whole rig, including operator, fuel, including the loader, then 1/2 of the rear track (distance between centers of the wheels, then an equivalent hill slope that exceeds this ratio. So, lower c.g. and wider track improves your statistics. The wet grass adds another element (the killer): sliding sideways reduces the static grip of the tires, so the tractors sideways velocity comes into play. Either you hit bottom and the outside tire quickly digs in, or the tire catches on a depression, rock, berm or because it sinks into a soft spot. The jolt causes a tripping motion because the stalled sliding momentum cretae a very large rolling moment (force x distance). This also means that if it starts to slide , you have some time to lower the bucket if possible or use the drive torque to help you steer downhill so that when you hit bottom you are mostly pointed downhill.
OK, so most tractors nowdays have 2 front wheels and an axle pivot with zero rolling resistance provided. On cars and trucks, you have a front anti-roll bar to balance the sidegrip and to reduce the roll angle in turns and banked hills. Why aren't front anti-roll bars offered on these machines? It's not because of additional weight. Extra cost, maybe. Or is it because they now recognize the need for a front bar, it's a safety concern, and this requires, maybe by law, a retrofit of all existing machines with these parts. We saw this on cars when anti-lock brakes came out, air-bags before that. Manufacturers 'knew' that there was a risk but did little or nothing to implement them, I remember GM offered airbags on 1973 Chevy Impalas. NOBODY wanted them. The government gave automakers a pass. Remember Day-Time Running lights ? People on this very forum stated they absolutely did not want their high beams on when they were driving. They never realized, knew, or believed taht the high beam BULBS were used at about 10% of their current/wattage to give you much more daytime visibility.
I wonder how many here would even consider making, buying, and then having to add a front roll-over resistance feature or components to their tractor. Heck people I know want the rear tires as far inward as possible because they want the tread covered by the fenders. Outward is more safe, but now it looks funny, the tires are wider than the tiller, you get TWO grooves in you lawn, or now it doesn't fit on a trailer.
Evinrude Johnson 3x13.75x13 Aluminum Marine Motor Propeller (A66734)
Evinrude Johnson...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
2017 Dodge Grand Caravan Van (A66738)
2017 Dodge Grand...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
