What caused this (pics) gouges in top of head
/ What caused this (pics) gouges in top of head #1
parluskq
wise va
honda 5013
When I took my head off this evening i noticed there were big gouges taken out of the top of the head above the piston, The piston looked fine, so did the valves. The cylinder wall looked good too but it looks like it had been honed. It almost looks like part of a spark plug or a piston ring has broken off at one point and just wreaked havoc on the head... I would't imagine it would hurt the function of the engine, or will it? The engine is a 16hp B&S Cast iron 1979 model... 10418462_702838414949_7397183080601045290_n.jpg10806211_702838434909_6945787781044076212_n.jpg10881575_702838385009_2248685090579927331_n.jpg
/ What caused this (pics) gouges in top of head #2
Welcome to TBN.............
It does look like a piece of loose metal was in the cylinder beating up the head. Is there a reason you pulled the head off. Was it making noise, knocking. If not put it back together and do a compression test. That will tell if a valve or rings are bad. If compression is good I doubt the gouges will affect running operation.
/ What caused this (pics) gouges in top of head #3
Check for loose or missing screws on the throttle or choke in the carburetor.
I just traded for a non running Terramite... I got the engine running, no bad noises, knocking etc. This is a winter project so I figured I would lap the valves, check the piston and cylinder walls etc when I noticed the gouges. I would imagine that this engine has had to been rebuilt, there is no scars in the top of the piston or on the walls and the top of valves other than carbon deposits look good. Once i lap the valves, I will do a compression check.
The carb is new... The guy gave me the old one, i will check it. I am thinking this had to have happened way in the past for the valves to no be torn up or gouged.
/ What caused this (pics) gouges in top of head #6
Also the top of the piston has no marks.
I would try to smooth the rough edges on the head if there are any before I put it back together.
/ What caused this (pics) gouges in top of head #7
Maybe a piston has been replaced, Definitely looks like something made it into that chamber at some point.
/ What caused this (pics) gouges in top of head #8
Looks like it has been repaired, at least a new piston put in. The top of the piston would look like the top of the head other wise. Do as others have said and put it back together and do a comp check.
2025 NATIONCRAFT 6X12TA2 T/A ENCLOSED TRAILER (A67148)
2025 NATIONCRAFT...
2002 Chevrolet Express 3500 Shuttle Bus (A64194)
2002 Chevrolet...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
2014 Toyota Camry Sedan (A64557)
2014 Toyota Camry...
2007 Isuzu NPR-HD Crew Cab Knapheide Service Truck (A64556)
2007 Isuzu NPR-HD...
UNUSED RAYTREE RMLL60-60" HYD POWER RAKE (A65055)
UNUSED RAYTREE...
