TripleR
Super Star Member
- Joined
- Mar 5, 2009
- Messages
- 18,538
- Location
- Missouri
- Tractor
- Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
No worries Triple R,
The first 9 Caroni flail mowers in the chart will be adequately powered for 20-30 horsepower tractors.
Models:
TL0900ASC
-TL0900FSC
TL0900PSC
TL1200ASC
TL1200FSC
TL1200PSC
TL1500ASC
TL1500FSC
TL1500PSC
For the Kubota 2660 The TL1200ASC would work well in my opinion with plenty of useable power from the P.T.O., front mounting option with the Pronovost front hitch and their reversing gearbox powered by the Mid P.T.O.,
or the rear the mounting option using the 540 R.P.M., P.T.O.
The front hitch allows you to use the P.T.O., rear mounted implement with no issues or changes.
Leon, thanks for the information, I apparently overlooked something on the website; not an uncommon thing. I am getting a little long in the tooth to change my ways, but I may very well buy a flail mower one of these days.
I'd guess that we have well over 500 BX tractors out at this point probably closer to 700-800 and I'd say that we do not do but a couple a year max according to our parts movement! That is a small number for the uses and the jobs and over use or abuse being point blank that people have told me they have done.
Now for those that have had issues with coolers leaking from foreign objects, or, a loose connection and a leak? On one make those units,,,,ready more then one in ten sold!!!! not a cub cadet though!
I have trouble not being able to find a fault with any machine built!
Some far more so then others for the numbers sold!!!!!!
Art, thanks for the information, based on the number of people on TBN reporting problems, I would have thought the number of problems would have been higher. I am not a mechanic, but it just seems to me that the oil cooler is a "better" design than the fan. I don't know of any of the larger units that have this and it appears as though newer design SCUT's are going to the coolers.
If the fan was indeed more reliable, why go with a more expensive cooler?
Like I said, I am not a mechanic and may be way off on this one, but if I had the choice, it would sure take a lot to sway me to a fan over cooler model.
As I said previously though fan or no fan, these little things are so low to the ground, I would put skids on no matter. I get mine off into the brush and have already torn one set of tie rods up and my son in law has torn those up on my old BX2200.
