What Brake Control would you get?
   / What Brake Control would you get? #1
chucko
Polk Co , Fl
bx1800
for a 28" travel trailer? I had a time delay type on my Dodge and it seemed to jerk a lot and it seemed when you get it set right for the open road it was not right for when you had to jump off to the city
   / What Brake Control would you get? #2
For me it's a question of what WILL I get... to replace the Reese electronic (time delay) unit I have now. It's miserable. I'll probably get a Tekonsha Prodigy. I've heard very good things about them /forums/images/graemlins/smile.gif
   / What Brake Control would you get? #3
I have a Tekonsha Prodigy and I have never had a problem with it. I pull a 20' tandem axle car hauler with my JD TLB set up. /forums/images/graemlins/cool.gif
thanks guys,
Prodigy was the way I was leaning but I did not want to say it to see what was said here first.
   / What Brake Control would you get? #5
I also recently installed a Tekonsha Prodigy in our van for our car hauler trailer. Installation was very easy. The van doesn't have the factory wiring plugs like pickup trucks so I had to tap into wires under the dash and behind the walls and under the capet and all that in the conversion van. Even with all that, it was very easy.
   / What Brake Control would you get? #6
Master Brake seems to be a good one. I recently bought the brakesmart controller. I havn't used it yet as I havn't bought a trailer, but it comes highly recommended on the RV forums and thedieselstop.com. It measures the brake pressure only so it doesn't act up on hills. My second choice based on the available info I had would be the prodigy.
   / What Brake Control would you get? #7
Jordan is another good brand. More info than you'll ever want about controllers is available at the forums for rv.net. Here's a recent thread that discusses the best ones:
RV net thread on controllers
If you rv and don't go to that forum it'd be like having a tractor and not coming to TBN.
Phil
   / What Brake Control would you get? #8
Not on a travel trailer.. but used on my 16' car hauler and horse trailer, it is a draw-tite activator II.
Has selectable tension, as well as speed of braking, whether to engage fast or slow. Also has a 'dead mans switch'.
I have it on my dodge and yukon, and had it on my ranger before I traded it.
Soundguy
   / What Brake Control would you get? #9
I will add my support for the Tekonsha Prodigy. Just don't know how well it will work on a <font color="blue"> 28" trailer </font>. /forums/images/graemlins/grin.gif
Here is a site that has a good deal on the controller. www.brakecontroller.com
It's where I purchased mine from.
would any of the Inertia Activated Brake Controllers be about the same? There seem to be some out that that don't cost nearly as much even some made by Tekonsha
BUSH HOG BH215 - 5' ROTARY MOWER (A51406)
BUSH HOG BH215 -...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
