Box Scraper What box blade to consider??
   / What box blade to consider??
Since I've mainly used the fel I was completely green to the 3ph, but I think I'm starting to get it now. I built and have been using a draw bar on only the bottom arms, I welded tabs so it won't spin around. When towing things, especially my heavy fish/ski boat, the load would flop side to side sometime violently going in reverse. I never tightened the turnbuckles(don't have side supports)I left them loose so I could get the bar on and off easily. Now I understand why all the slop and flop. Thanks Fallon. So I should loosen the turnbuckles to hook/unhook implements, then tighten them to each implement's fit? Now I see what all the talk is about quick hitches. If I had/used more equipement it might be worth the expense, but not yet.
TripleR, what did those pin-adjustable stabilizers cost you?
   / What box blade to consider?? #22
I've bought so much stuff, I hope I am remembering correctly, I believe it was about $130, they are sold by another TBN member hodge, a great guy with whom to do business: http://www.tractorbynet.com/forums/attachments/235360-explanation-replacement-stabilizers.html
   / What box blade to consider?? #23
Sounds about right. Flopping around while moving generally means wear & tear plus a greatly increased chance of breaking things. Not to mention precision & control issues.
Be very careful about towing using your 3pt hitch. If you suddenly stop or go down a dip, the trailer can push the 3pt up. A 3pt is designed to lift things, not push them down. As soon as a load gets above the rear axels, bad flipping over type thing get very possible. Is recommend a little reading in the safety forum on the topic.
Personally I do own & use a 3pt hitch trailer mover. I'm mostly moving empty trailers slowly short distances though. If I were moving bigger loads or using it often, I'd be hitching to the drawbar.
I only move things around in my own yard, very slowly, carried low and then very rarely. But I never adjusted the turnbuckles, I think that's why I had an over-abundance of slop. The next time I attach something I'll tighten the stabilizer turnbuckles and test for slop factor.
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
ELECTRIC TRICYCLE IRET13 (A55745)
ELECTRIC TRICYCLE...
MINI EXCAVATOR BUCKET 32 (A55745)
MINI EXCAVATOR...
SHOPMADE GOOSENECK CASING DRILL PIPE HANDLER TRAILER (A55745)
SHOPMADE GOOSENECK...
2000 JLG 600AJ ARTICULATING LIFT (A55745)
2000 JLG 600AJ...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
