Loader what are these fittings on the bucket designed for?
   / what are these fittings on the bucket designed for? #1
chrisss
Kubota L4310
Can anybody tell me what these features on the upper outside corner of the FEL bucket are for:
1. The strap on the side of the bucket (which I have a chain running thru),
2. the hole drilled thru the side, lining up with a threaded stud about 3 inches inboard.
Thanks in advance.
   / what are these fittings on the bucket designed for? #2
Parking stand when you remove the loader.
   / what are these fittings on the bucket designed for? #3
Yep your missing the legs that go in the strap hole...
Hmm. There are legs/stands along the underside of the boom arms tho, which the manual talks about in the removal procedure.
Sounds like there are separate legs for the bucket too?
   / what are these fittings on the bucket designed for? #6
Different bucket?.....
That could be it.
Thanks all for the replies.
   / what are these fittings on the bucket designed for? #8
Doubt the bracket, holes and that tab with a hole in it were OEM features. Some kind of homebrew add-on. Loader on/off is easy with the factory parking stands, but wants a flat, even surface.
   / what are these fittings on the bucket designed for? #9
No there was a thread here before that showed a parts list for the loader parking stands I think that was the old style before they changed it......I looked for the thread but could not find it...
   / what are these fittings on the bucket designed for? #10
I can't see why they are for parking the loader, that would put psi on the couplers all the time and then you couldn't hook back up.
   / what are these fittings on the bucket designed for? #11
With the straps, stands in place curling the bucket lifts the back end of the loader out of it’s mounts.
   / what are these fittings on the bucket designed for? #12
Whatever that is on the bucket is not for removing the loader. As mentioned, you use the stands under the lift arms and that's a common Kubota thing. I've seen many of them in use. Your bucket does look like original paint but it's possible it's a modification. It looks more like some auxiliary piece of equipment that attaches to the bucket. I think I have seen those side brackets before but can't recall where or when.
   / what are these fittings on the bucket designed for? #13
W.A.G.: Mounts for some kind of home made grapple add on?
Are they on both ends of bucket?
   / what are these fittings on the bucket designed for? #14
   / what are these fittings on the bucket designed for? #15
Strange: I used them many times to remove the loader on my Kubota!
   / what are these fittings on the bucket designed for? #16
Most of the time the brackets (legs) get lost or missed placed....
   / what are these fittings on the bucket designed for? #17
Mine were also used to add a little support to the loader arms when it was in use. Pretty hard to lose them.
   / what are these fittings on the bucket designed for? #20
The legs mounted on the loader arms.
Nice bucket. Typical of welded on hooks on a material bucket. Not meant for weld on (or bolt on hooks). Have one here in the shop I need to straighten out for a customer and I will remove the hooks when I do and toss them on the scrap bin. I see lots of buckets with 'smiles' in them. All have bucket hooks it seems like.
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
S/A Yard Dog Truck (A59230)
S/A Yard Dog Truck...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Ryan Greensaire 24 Walk Behind Aerator (A59228)
Ryan Greensaire 24...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
