What are rated speeds for 6000?
   / What are rated speeds for 6000? #1
Slippy
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
Anyone know the rated speeds for the 6000 4wd? Trying to determine what gear and range will provide a ground speed of 4-6 mph.
Thanks.
   / What are rated speeds for 6000? #2
Have you looked in your owners manual? Sorry that I can't help.:(
   / What are rated speeds for 6000? #3
Fourth or fifth gear will be awfully close at PTO rpm.
Hope this helps.
I think the speed for each gear at PTO rpm is posted on a decal on the inside of the left fender. Need to look at my tractor to be sure.
   / What are rated speeds for 6000? #4
Low 3 or 4 should be the closest @ 2100 rpm
Ahh...I found it in the manual. Guess I should have looked there first.
Low range 4th gear ground speed = 4.3 mph
High range 1st gear ground speed = 6.1 mph
These speeds would be with pto at 540, which is about 2100 rpm.
Of course what I would like to have is also something right in between there.
Thanks.
   / What are rated speeds for 6000? #6
I've always said the 6000 needs at 4th and a half gear!!! It would be nice to have another slot in between those two.
Glad you found it.
I agree. 4.3 is a little slow and 6.1 is a little fast to pull my baler. The 6000 does a real nice job pulling it though. Even on the hills it is real does fine.
   / What are rated speeds for 6000? #8
Yes, I bale in 4th gear for the most part and that is just about perfect. My 200+ acres are steep and hilly and the 6000 takes it in stride.
Every now and then I wish I had a 6530 with the levers and controls on the side.
The forward and reverse lever gets a little old after a while. I have now baled about 500 5x4 round bales. After 5 hours or so of baling I am pretty tired of the forward reverse lever. Thinking of adding a kicker to my baler, but concerned on the hills I might kick one off. I am covered with grass dust as well. Cab would be nice too.
In low range 4th gear the tractor, baler and I are all ready to go a little faster. I am amazed at how fast the baler will eat up the hay, even the clumps.
   / What are rated speeds for 6000? #10
Maybe you should think about looking at one of the 8560s with a cab, if they ever get out for sale. More gears and clean air, :D just a thought.
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
18002 (A51691)
18002 (A51691)
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
20' One Trip Shipping Container (A50514)
20' One Trip...
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
