Snow West Virginia snow,
/ West Virginia snow, #1
Newtogreen
Bronze Member
Harpers Ferry,West Virginia
JD 4115
Well I just came in from getting my butt whipped here in Jefferson County, West Virginia. My JD 4115 with 6 1/2 ft Curtis power angle front blade took all it could handle. The snow is very heavy and coming down hard. I looked like a snowman so I decided to take a break and wait until morning. This storm could do a lot of damage. Thanks for listening.
/ West Virginia snow, #2
Looking for pics :)
Hoping for snow here, but not getting any.
/ West Virginia snow, #3
Same here in Preston Co . at 6pm ,we had 8-9 " my brother ,is closer to the MD line and just inside the higher mt range snow belt, he had 11" ...
Been snowing and now blowing like crazy..I'm guessing we have gotten another 6-8 " since I was out..Calling for us to get 12"+ till noon or later when storm moves out of the area...
Will get up in the morning and blow out the neighborhood...
/ West Virginia snow, #4
We already have 12",that's the most we were supposed to get. Still snowing to beat the band. With another five or six hours to go,if the intensity stays the same as it's been for the last five hours,we may end up with close to 20":):( We'll see how well my 2520 performs.
Greg
/ West Virginia snow, #6
I live near Charleston and the storm for us till now has been rain. I measures it a while ago and it was over 2 inches in the rain gauge. Started snowing at about 9PM and they are calling for a storm total for us of between 4-8 inches. I will believe it when I see it. I don't mind missing all of this heavy snow cause I would have to go to work till who knows when. Be safe guys out on the machines tomorrow its easy to get hurt but this is where our toys I mean tools shine the brightest. Have fun.
/ West Virginia snow, #7
I live a couple of miles from the Preston county line at the top of snake hill road. Just came in at 11:30 pm from plowing the second time today. Measured 21" on the table on the back deck. Some may be blowing off roof, not much though. I have 16" muck boots and it is well up over the tops in my yard. Power has gone out a couple times briefly.
I will be digging out from this for days. Have the chains on my Ranger and moving snow banks back with the tractor. So far so good. -Keith
/ West Virginia snow, #8
KeithT Not sure how much we have now because I came in around 530-6p ,but everytime a car has driven by it has been snowing like crazy..
Just guessing somewhere around 16" or more...
You're up higher like my brother and he had a 11"-12" at 6pm in at Hazelton.
/ West Virginia snow, #9
Well, the snowmobilers around here are hoping for more snow, but thankfully this storm is scheduled to swing east and out to sea before it gets as far north as NS! :):):)
/ West Virginia snow, #10
It's still coming down hard in central VA. I went ahead and took the FEL off my 790 and put the snow blade on. Actually, I really like the FEL for clearing snow because I can make big piles with it, but the snow plow is a lot faster. Like etcallhome, I'll probably end up plowing the neighborhood. Also, for some reason the front blade doesn't leave as "slick" a surface as the FEL edge.
Fortunately, I think we have enough snow that I feel good about firing up the Cat D4. At 20,000lbs and packing a 10' wide blade, it'll move some snow....
For an update, its still snowing here in Jefferson County, West Virginia. I just came in from digging out the heat pump and some spots on the roof that are well over two foot. I am debating on getting the 4115 out now or wait until the snow stops. I am glad to have plowed some last night because this stuff is deep. I wish I had a snowblower but the front end blade is fine. The only problem with the 6 1/2 ft Curtis power angle blade is the weight on the front boom but I have plenty of ballast in the back with a heavy disc harrow. This setup looks like it would break the tractor in half but its a tough machine. Thanks everyone, Larry
/ West Virginia snow, #12
From what reports I'm hearing here on the west coast, sounds like that D4 might just be the right machine for the job. :)
Be safe and stay warm.
/ West Virginia snow, #13
Pix?
Haven't seen any good snow since last winter. Be safe and stay warm.
/ West Virginia snow, #14
We woke up this morning with 18"+ 8+ snowed another 4-5 since this morning and still snowing. Been out 5 1/2hrs came in for lunch and then going back out.!!
Heard one report that Oakland Md had 32" this morning.
daughter in Martinsburg 24+
Let it snow,let it snow, let it snow !!!!!
/ West Virginia snow, #15
Newtogreen, I feel your pain. I'm here in Berkeley County, WV and we have 4 ft-plus snowdrifts at the front and rear door and well above 30 inches of snow in the remaining parts of the property. I used my JD4110 with loader and rear blade to clear things last night, but with the blowing snow, you can't tell I did any work at all. Like you...I will be looking at buying a snowblower for the 4110. Think I'm going to wait until it's all over before I try again, which looks like it will be about 10pm tonight in our areas. Good luck!
/ West Virginia snow, #16
Just a little advice for you folks not used to large amounts of snow. Up here, roofs are designed with snow load in mind, I don't know about down there.
You *might* want to shovel your roof before you plow. Not as much fun, I know, but.....
/ West Virginia snow, #17
Thanks everyone seen your posts so I had to call to check in up there.
Mt Nebo 18" and still falling. Not to Bad :rolleyes:
Carey
/ West Virginia snow, #18
glc24 what part of SW pa are you in,,
Hello et
I am in Big Beaver Borough, which is part of Beaver Falls. We are about 5 minutes away from Chippewa. We ended up with 22". I know one thing for sure,I need a snow blade and chains on this bad boy. I had to dig it out 3 times:mad: Two weren't bad,but I fell of the side of the road (couldn't tell where in the heck the road was) and that was a bugger. My truck wouldn't budge it,four people and an hour and a half later it was back on level ground.
I used to like snow:rolleyes:
Greg
/ West Virginia snow, #19
glc24 know what you mean about getting stuck.. Same thing happened to me had 5' rear blade ,setting straight across , and 47 blower on frt...Got to close to edge down far enough I couldn't come back up on road..I even shoveled , and turned rear blade to inline with tractor. Yelled for my father in law ,pulling me backward and with him going backward down hill ,state had just plowed and ashed he had a hard time getting me out..
I did 14 driveways plus church parking lot. Started at 7a, came in for 30-40 min went back out and walked in house tonight at 7pm
One long day but 47 blower did a go job ..
/ West Virginia snow, #20
I'm sick of all this snow.- If i could get the D9 or D10 that i operate at work, and bring it home.-Then i would be in great shape.;)
