Well Pump Sizing??
/ Well Pump Sizing?? #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
I have a 170' deep well that feeds my house, any yard watering and filling stock tanks. The house has three full bath rooms, kitchen and laundry. In an out building there is a 1/2 bath. In the future we'll be adding another bath room in the house either a 3/4 or 1/2 and I'd like at least a 1/2 bath in the garage at some point (if we ever build a barn a 1/2 bath would be great there too).
The current pump is a submerged pump with 2 wires IIRC, but I don't know the HP (we've only owned the place a year).
Possible future uses may include sprinkling some pasture grass in extreme conditions like this year since we are past 45 days with no rain.
I want to plan for a future well pump replacement what size pump should I look at getting as a replacement? Is just getting the biggest best? I think 1 HP is the largest size submersed well pump I've seen.
ps the previous owner used the well/pump to fill the one acre pond here when it was built about 3 or 4 years ago, so the current pump maybe living on borrowed time.
/ Well Pump Sizing?? #2
Is the the pump all the way to 170' depth of well? Some times well depth is not same as pumping depth. You need to have an idea of your pumping head, that is how far up your pump can push a column of water till it quits moving anymore water, or gpm desired.
2.31 feet of head = 1 psi.
A typical residential 3/4 water line with a meter flows about 5 gpm at 45 psi. (give or take a little)
It is important to know on pump selection, its pump curve to determine if that will do what you are asking it to do. HP is not a good determining factor.
My best advice is talking to a local well driller, to see what style of pump would be best for the USE you have in mind, and what water quality is there. Some water is hard on different styles and or materials of pump.
When you change that pump, put a air tube down with a pressure guage and valve stem much lika a car tire so you can find out with pressure guage a few times a year your pumping, and static level is doing.
/ Well Pump Sizing?? #3
You may want to start with the flow rate of the well and make sure that is not exceeded.:thumbsup:
Submersible pumps do come in larger HP sizes.:)
The guy we bought from said the well put out more than 150 gal per minute per the well driller. The town a few miles away wanted to buy water from the well.
I have know idea how far down the pump is. The line to the house is 1".
Where do you find the larger size pumps at?
/ Well Pump Sizing?? #5
The important metrics are (1) depth of water, NOT total well depth, and (2) desired GPM. If your well head is deep, then you need bigger pumps, however, if your well head is shallow (can you look down and see water?) then a too-big pump will cavitate and damage itself. The pump, regardless of depth, only pumps from the head level, not from where the pump itself sits. Every pump has a head depth vs. GPM curve. If your head is less than the lowest end of that curve, you can damage the pump. You can add pseudo-depth if required, however, by adding additional check valves in series (one at pump, one at pitless, one at tank - usually does it).
A typical residential pump runs about ~7-10 GPM or so. Pick a desired GPM, estimate your well head depth + line losses, then go to a plumbing supply house and they'll pick out the right pump for you. Gould is known as the best pump brand to get in this area.
Pumps usually last about 25 years. I wouldn't worry about filling a 1 acre pond, especially if the pump was running wide open the whole time. What kills a pump is start-stops, so short-cycling due to a bad pressure tank will significantly shorten lifetime.
JayC
JayC
Jay,
How do you find this out without pulling the pump?
If the pump has never been replaced its about 20 years old now.
/ Well Pump Sizing?? #8
dieselscout80
If 20 years old, you will find out shortly (within a few years) when you pull the pump. :D
Just replaced mine, and the pump (1 hp) was down at 260'. Put the new pump (1.5 hp) down at 270'. The well is dug to 320'.
I let the pump/well guy put down the pump they handled, as then any problem it is up to them to fix. Are you planning to pull this yourself?
Look around the pump control box for depth information, or in some states there is a well report on file with the state (is in WI) when the well was first drilled (or pounded). Other than pulling, likely no other way to measure pump depth.
dieselscout80
Why did you switch to a smaller HP pump?
/ Well Pump Sizing?? #10
Didn't....went up to 1.5 hp from 1 hp. :)
/ Well Pump Sizing?? #11
JayC
If the pump is too larger and doesn't have enough head it will not go in to cavitation
It will go in to over current and burn up if not protected because it is designed for a given head and it isn't there.
A submersible pump normally wont go in to cavitation because the water over top of the pump makes volute a positive pressure,
The lack of pressure in a pump volute reduces the boiling point (think opposite of pressure cooker or radiator cap)
causing a "sand blasting" in the pump as the water burst into a boil.
tom
/ Well Pump Sizing?? #12
Wouldn't the amperage drop when less water is pumped?
If the motor is on the bottom of the pump it should stay in water and be cooled. :)
If the motor is on top of the pump it can be left sitting without any cooling water and overheat:)
The pumps are usually sized so as not exceed the recharge rate of the well.:)
/ Well Pump Sizing?? #13
I don't know all the engineering stuff most what I learned was from fire house training and repairs at work.
When the flow from the pump stops the pressure will go to the top of the pump curve (called dead head) if the motor was selected correctly it will just sit there and the motor will drawl full current.
With no flow the consenquences are the water churning in the pump will heat up and it does it faster than you will think .
When the inlet of the pump has a higher than designed pressure (more water in well) the centrifugal pump will increase the flow and only over loadI cant explain why but that is how it works in real life.
I probably have changed 5 or 6 pumps or motors in my 30+ year carer because they weren't selected right and burnt up due to not enough head.
tom
/ Well Pump Sizing?? #14
When the pump is dead headed the amperage drops. Check it with an amp meter.:D
Yes, the water will heat up.:)
In some cases restricting the pump outlet flow is used as a means of flow control.
The actual work the pump does is figured from the well water level. Addition work will be from friction loss in the line below the well water level.:)
There is insufficient flow through the pump to provide the required cooling.:)
/ Well Pump Sizing?? #15
I haven't figured out how to brake the Quote up
You are right my fingers didn't put what my brain was thinking
What I was trying to convey that current will be there (although not full) even with no flow.
I was referring to the motor burning up in the last statement not the pump head it self
tom
/ Well Pump Sizing?? #17
That can happen when the downhole pump capacity is greater than the recharge capacity. The motor needs the fluid flow to cool itself.:D
/ Well Pump Sizing?? #18
My advice is to just go with the flow. Even though you are adding fixtures etc. the chances of them all being on at the same time is low.
Sometimes you can tell the HP of a pump by looking at the control box. 2-wire pumps do not have a control box but you can look at the amps to see what HP the pump is.
The lifespan of a pump is certainly not 25 years, although I have seen a few outlast that number. The current lifespan is around 7-15 years, depending on use and brand.
You can get 4" pumps up to 7-1/2 HP.
I wouldn't worry about it. Just rock on until you either notice that it's not keeping up with demand or it gives out, then talk with your well driller/pump guy and let them do the job. It's NOT a DIY job.
Will a higher HP pump that is not having to work as hard last better than a lower HP pump working at max capacity?
/ Well Pump Sizing?? #20
With a downhole pump that runs at a constant rpm it will always be pumping at a fixed rate[hard as it can] unless it runs out of liquid to pump.:D
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A61572)
2006 Snorkel AB50J...
20ft trailer (A61569)
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
2009 STRICK 53X102 T/A DRY VAN TRAILER (A59912)
2009 STRICK 53X102...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
