Well Pressure Switch Isolation
/ Well Pressure Switch Isolation #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
Has anyone been successful in devising a way to keep all bugs out of your pressure switch? I regularly have the switch inoperable because ants and such get between the contacts.
I SUPPOSE that I could get the switch installed inside some type of enclosure that I would then make absolutely bug-tight - this would be kind of involved though, probably involving caulking and many other techniques. But once I get it perfectly isolated into that enclosure, would that environment be too hot for its operation.
Let me know if you have had success, or know of a commercial product, or have any other advice. I don't know if there is another type of switch which does not use contact points.
Yes, I keep the area sprayed with bug poison continuously.
Thanks, Martin
/ Well Pressure Switch Isolation #2
You could get into industrial switches but the price is rather high.
Suggestions: duct tape and plastic bags, silicon seal:):)
/ Well Pressure Switch Isolation #3
I had a small treefrog get in thru a hole that had a missing plug. Fried the little froggy, took down the well... I replaced the pressure switch, and made sure all the holes had plugs.
/ Well Pressure Switch Isolation #4
There is a plastic water proof electrical box for outdoor use. lid is held on by 4 screws.
wp connectors to seal the wireing and same for the pressure line.
ken
/ Well Pressure Switch Isolation #5
I had that problem several years ago. Thoroughly wrapping the switch with electrician's tape fixed it.
/ Well Pressure Switch Isolation #6
Poor little guy was probably after the ants. They are attracted by the electromagnetic field.
Case 1845C Uni-Loader Skid Steer (A62679)
Case 1845C...
2019 Bobcat S450 Compact Wheel Loader Skid Steer (A61572)
2019 Bobcat S450...
Challenger 65C/70C/75C/85C Tractor Parts and Service Manuals (A63117)
Challenger...
Attention (A57148)
Attention (A57148)
iDrive TDS-2010H...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
