Well Pressure Switch Isolation
/ Well Pressure Switch Isolation #1
SLOBuds
Gold Member
Los Angeles/Central Coast, California
Kubota L35
Has anyone been successful in devising a way to keep all bugs out of your pressure switch? I regularly have the switch inoperable because ants and such get between the contacts.
I SUPPOSE that I could get the switch installed inside some type of enclosure that I would then make absolutely bug-tight - this would be kind of involved though, probably involving caulking and many other techniques. But once I get it perfectly isolated into that enclosure, would that environment be too hot for its operation.
Let me know if you have had success, or know of a commercial product, or have any other advice. I don't know if there is another type of switch which does not use contact points.
Yes, I keep the area sprayed with bug poison continuously.
Thanks, Martin
/ Well Pressure Switch Isolation #2
You could get into industrial switches but the price is rather high.
Suggestions: duct tape and plastic bags, silicon seal:):)
/ Well Pressure Switch Isolation #3
I had a small treefrog get in thru a hole that had a missing plug. Fried the little froggy, took down the well... I replaced the pressure switch, and made sure all the holes had plugs.
/ Well Pressure Switch Isolation #4
There is a plastic water proof electrical box for outdoor use. lid is held on by 4 screws.
wp connectors to seal the wireing and same for the pressure line.
ken
/ Well Pressure Switch Isolation #5
I had that problem several years ago. Thoroughly wrapping the switch with electrician's tape fixed it.
/ Well Pressure Switch Isolation #6
Poor little guy was probably after the ants. They are attracted by the electromagnetic field.
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
2016 Freightliner 114SD T/A Lely 3,300 Gallon Septic Wet Vacuum Truck (A61573)
2016 Freightliner...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
