Snow Well I finally did it !!!
   / Well I finally did it !!! #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
As careful as I am, I finally forgot to release the frikin brake before clearing my drive. Ran about an hour before I discovered it. .... da** !
I just had the tranny fluid changed this fall too. I wish Kubota would have put an idiot light on dash to let you know when the brake was on.
I didn't have it engaged too much, but even that is bad.
Pay more attention next time for sure.
   / Well I finally did it !!! #2
Have you try brakes on slight slope to see if you still grab?
Pretty sure your not the first nor will be the last...trust me. ;)
   / Well I finally did it !!! #4
It makes you feel stupid when you do that. How can I not feel that the brake is on I say to me. :confused3:
gg
   / Well I finally did it !!! #5
When I lock the brake pedals when parking my tractor, I do so with more than enough force to ensure I will KNOW THE BRAKES ARE ON should I try to move it on the next startup without removing the brake. There is no way I can move and not realize I'm chained to a tree, so to speak. Can your brakes be applied with that kind of force?
   / Well I finally did it !!! #6
When I lock the brake pedals I do so with more than enough force to ensure I will KNOW THE BRAKES ARE ON should I try to move the tractor without releasing the brake.
My methodology too.
   / Well I finally did it !!! #7
Can not apply my brakes tight enough to feel like it is chained to a tree on my BX2230. Jon
I rarely ever use the brakes. It was just that today when I pulled it out of the garage to let it warm up, it wanted to creep back towards the closed door. So I put them on enough to hold it. Dumb on my part. I should have let it go a little and see if it settled out. I will next time.
   / Well I finally did it !!! #9
This is the biggest complaint I have about my B3030HSDC. I have done this several times over the past 4 years and always felt like an idiot. Kubota, put a frigging red idiot light on the dash whenever the brakes are locked on. You have all kinds of electronic sensors for other idiot situations, why not this simple one? Better yet, give us a retrofit kit and I'll put it on myself!
   / Well I finally did it !!! #11
My kubota has a brake light in the dash, I just wish there was a 4wd light in the dash.
   / Well I finally did it !!! #12
I had a friend who was "helping" me one day, he wanted to drive the 1989 J.D 2555 cab tractor I had, it was about a 1/4 of a mile and the brakes weren't too awful good to begin with. He gets over to where I need the tractor to pull a log out of the woods and he ask me "what's this light on the dash?" I said the parking brake and proceeded to feel my blood pressure boil. I could have throat chopped him, he was the parts manager at a J.D. dealer. I guess because you can look parts up on a computer doesn't mean you can read the dash lights, lol. Sold it several years ago. I don't understand why Deere went away from the "park" on the gear stick. Park is awesome, if you've ever been on a tractor with it.
   / Well I finally did it !!! #13
I've ran my grandfather's CaseIH with the brakes on for a pretty long while. It has a bright light in the dash, and other lights in the dash that flash, but the switch isn't very reliable. It extends to close the circuit, and tends to stick until you clean it out. If it compressed to close the circuit, at leas then the worst case would be that the lights stay on when they're not supposed to. What good is a safety/warning light if the switch isn't reliable? Plus to set the parking brake you pull a hand lever that is completely independent of the foot pedals so you don't notice it. All of our other tractors you set the parking brake by locking the foot pedals down and it's kind of hard not to notice the parking brake is set.
   / Well I finally did it !!! #14
Been there, done that. I wish my john deere had a light to let you know the park brake was engaged, as well.
   / Well I finally did it !!! #15
My Ford has a hand park brake that I use a lot. I learned right after buying the tractor to put the park brake on very firmly. Then you won't drive off with it on. Lesson learned. :)
   / Well I finally did it !!! #17
My NH has an idiot light on the dash. I still try to drive off with the parking brake engaged. Thankfully it is one that has to be set so tight you feel like you are chained to a tree. So I go about 3 feet at most before realizing.
   / Well I finally did it !!! #18
When I first got my Kioti CK2510 HST I drove with the brakes on several times, then I adjusted them and now when the brake is locked on you know it!
   / Well I finally did it !!! #19
I put a red LED on the dash of our B2650, believe it or not their was already a wiring harness for it. Go figure.
JOHN DEERE CP24 ASPHALT PLANER (A60429)
JOHN DEERE CP24...
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
New Holland T2420 (A53317)
New Holland T2420...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
