Welding Splitter Wedge, Help Please!
/ Welding Splitter Wedge, Help Please! #1
Prodirt6000
A friend wants me to cut his 4 Way wedge so it is just a single. Is it ok to just use the torch?
I also need to re-weld the single wedge to the frame. Whats the best way to do this? Preheat to cherry red...then....?? Whats the best electrode to use?
Any suggestions would be great help.
I'm a pretty good welder, been schooled and all, just need some more advise for this here. Dont want the weld to break for this guy.
Thanks
I'm not exactly sure what type of steel it is. I was hoping maybe you guys would have an idea. Is there a steel that is most used for wedges?
/ Welding Splitter Wedge, Help Please! #5
I got tired of squishing home made wedges and bought three of the ones you smack with a maul and welded them one on top of the other. I used fresh 7018 at around 140 amps and they have never come loose....I'm surprised too.
/ Welding Splitter Wedge, Help Please! #6
Most wedges are standard low carbon steel, that is what mine is. We welded it on at 150 amps DC+ with 7018 rods, three passes.
James at PJ commercial products sells a hardened wedge, it costs 32 dollars an inch, so a ten inch wedge would be 320 bucks... And welding it on would require somebody who knows what they are doing. (like not me...)
Good luck
Wayne
/ Welding Splitter Wedge, Help Please! #7
I also did mine with 7018,but with my ac welder.Has held all these years no problem.Wedge is a NORTHERN TOOL ,welded to an i beam.
ALAN
/ Welding Splitter Wedge, Help Please! #8
I would weld the first pass with E6011 that is a deep penetrating rod.
Clean up the slag. I mean really get rid of the slag!
Finish it with E7018 two or three more passes. That should hold for a good long time.
/ Welding Splitter Wedge, Help Please! #9
The reason I didn't use 6011 for the root was the unknown composition of the wedges....
/ Welding Splitter Wedge, Help Please! #10
7018 is deep penetrating itself, you do want the amps cranked up with 1/8" min rod.
I like the idea of the 3 wedges stacked together, quick poor-man's fix.
/ Welding Splitter Wedge, Help Please! #11
On stacking the wedges....I took them to the grinder and removed some of the "flare" at the tip and stepped them so the top ones were closer to the ram. It was a cheap solution....and I'm really suprised that none of them flew off into the beans. Corn wouldn't have been too bad....but with beans..I never would have found them!!
/ Welding Splitter Wedge, Help Please! #12
my wedge was a "hardened steel" composition, and 7018 was recommended. torch in one hand, stinger in the other, i welded it on there . i am confident it will never, ever, breaK off.
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2016 Ford F-450 Liftmoore 2550 5,000lb. Crane Service Truck (A64556)
2016 Ford F-450...
2006 CHEVROLET TRAILBLAZER (A65054)
2006 CHEVROLET...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
