Welding rods
/ Welding rods #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Well you guys got me onto learning about welding so I might as well ask here as well as WeldTalk.
Got me a Hobart AC/DC Lx235 stickmate and I plan on starting to experiment with it.
It came with 6011, 7014 and 7018 rods. They've been in one of those enclosed rod holders for about 2 years now (says the guy I bought them from). From what I hear the 6011s should be fine. Figure I might as well burn the 7014s and 7018s up while practising.
I also bought some 3/32 and 1/8 6013s.
My questions are:
  • What rods would you start with for a beginner?
  • What are your goto rods for fabricating stuff out of 1/4" or 3/8" clean metal - e.g. say something like welding on a QA plate to a loader? I've learned here that the 6011s are a good goto rod for rusty or dirty stuff so I'll remember that for repairs.
  • For 1/4" material what thickness in rods should be selected?
Pretty basic questions but I'm pretty darn new at this so will appreciate any tidbits you can throw my way.
/ Welding rods #2
Look at the local welding supply store (or ebay) for books or cd's. That will get you a good start. And a place to look at for the correct way to use the rods, as well as applications, etc.
Since you have a DC box, you have a lot of choices compared to an AC only box.
6010 (dc)/6011 are great starter rods (first bead) and can be used to burn through things as well. They will work in rusty metal and are noted for their penetration.
7018 is a popular rod (ac & dc) for filling, and I think all positions (as is 6010/11).
I seem to remember 6014 or 6024 makes a real pretty bead, with the slag curling off as it cools.
The manufacturers all have good info sheets (a lot like gun powder, bullet reloading sites). Better than opinions and memories.
/ Welding rods #3
Ok, I'll take a stab at it. I'll try to keep it sweet and simple and give you some golden rules to go by ( I am not a welder by trade, just do some welding on the side ).
Your most popular goto rod should be 6010 and 6011. These rods can dig through some rust and grease and dig deep. Your 6013 will simply weld over rust and is most used for thinner materials up to a 1/4. 7018 and the 70 series rods are low hydrogen rods and like 6010 and 11 dig deep but deposit more material. The 70 series rods are moisture sensitive and so need to be kept dry in an oven or used soon after you open the packaging ( soon being a week or two ). Then there are your nickel rods for doing cast iron work. If you're working with thicker material, say 3/8 or thicker, vgrove your butt joints to get full penetration. It's good to do a first pass with 6010 or 11 and then subsequent passes with a 70 series like a 7018. You will get must better looking beads with the 7018 then the 6010 for example. Getting back to your point about welding 1/4 and 3/8. I would use either 6010, 6011, or 7018 if just making one pass. For thinner material, say thinner than 1/4, go ahead and use 6013. Also, the 60 and the 70 indicate tensile strenght, 60,000 psi and 70,00 psi respectively. Hope this helps.
/ Welding rods #4
In terms of rod thickness, don't go larger than the thickness of the material you are welding.
/ Welding rods #5
6011 seems to be a real popular rod on here however I have never had much luck with it. IMO it burns way too hot to get a good looking weld. But then again I am normally weldingmostly clean metal. As for a good beginner for mild steel, I don't think you can beat 6013 or 7014. they both are very easy to weld with. My dad always swore by 6013 just because of how easy it was to weld with. It took me awhile but I finally got him hooked on the 7014. IMO they weld about the same but the 70 series rod is stronger as noted above.
I havent used much 7018 as idon't have much use for low hydrogen rod, all we weld is mild steel.
As to the thickness of the rod, 1/8 is a good rod just to keep on hand for whatever comes up. If you are planning a job that you know is going to be a lot of thick stuff, like 1/4 +, get bigger rod like 5/32. If you got some lite work to do, less thatn 1/8", get 3/32.
/ Welding rods
Thanks for the posts folks.
Yesterday I lit up my first arcs. It was a BLAST! I was just playing with some 1/4 angle iron from scrap that I cleaned up just to run some beads on. This is all with DC+
I started with 3/32 6013. It was easy to light and to keep going. My welds were pretty crappy. Then I tried the 1/8 6013.
Overall
3/32 6011 was next. Overall it was MUCH tougher to light than 6013, lots of sticking of the electrode to the metal. It burned more 'voilently' :). However once I got it going, I thought the bead was much better than the 6013. More than likely because I just had had a bit of experience running my first beads with 6013 :). There as a fair amount of spatter with 6011 which made me think that the current was too high. I had the 3/32 6011 set at about 70 amps. However any lower and it was next to impossible to start .... waaaaaay too much sticking.
7018 was no use at all.... might be just because the rods were old. It left a lot of holes in the weld bead. I might try some newer 7018s to see what they woudl be like.
My favourite rod of all was the 7014. it was a 1/8. I set the amps to 120. I could not imagine that I'd be able to run as nice beads as I did on my first day doing this with this rod. The deposition rate was also really good. This rod was as old as the 7018s so it must store better - they were both at least 2 years old - stored on one of those plastic rod holders.
My overall impressions:
- I found 1/8 rods MUCH better to run than the 3/32 rods. I'm guessing the deposition rate matched better with the speed I was moving the electrode at.
- 7014 1/8 ways my favourite by far. Deposition rate was good. Arc was easy to start and very controllable. I could see the puddle nicely etc.
- 6011 was my next best. It was a 3/32. Layed down not a bad bead. It was a **** to start though. Way more times sticking the rod than starting an arc! Not quite sure if I have the amps set right. The instructions on my machine provided a range of 40-85A for 6011. I'm guessing from the spatter that I am running it too hot and just need to pick up a lot more skill at starting the arc (and not sticking!).
Things I am confused about:
- Current range on the 6013 rod package (I bought new rods) was different from what is listed on the quick guide on my welder. The lincoln provided range for 3/32 6013 was 70-100. On the Hobart I think it was more like 40-85. I'm guessing I should use what the rod manufacturer provides as a starting point?
- How much switching off and on of the welder should I be doing? Everytime the rod sticks, should I be turning the welder off - or just pulling the rod off and putting it back on the electrode holder? I found out that it didn't electrocute me if I just stuck it back in the electrode hold with the machine on :) I was wearing thick welding gloves etc.?
Am I generally fine leaving the machine on while I am putting a new rod in etc. as long as I make sure that the electrode holder does not contact the base metal?
- Duty cycle question. If I turn the machine OFF - does this count towards off time for the duty cycle?
/ Welding rods #7
Duty cycle is the percentage of welding time versus non-welding time with the machine turned on. If the machine has a cooling fan, it needs to be running to reduce the internal temperature of the machine.
/ Welding rods #8
Geeees, I've been DIY welding for years and have never really given much thought to using different types of rods... I've always picked up a box of 3.2mm (or 0.125in) rods from my local agri supplies store. ALWAYS keep them stored in my wifes hot press (nice n toasty) and have never really had problems welding.... I've never had a weld break on me and always seem to lay down a pretty good bead. My dad taught me to weld when I was a kid. Practice and patience are the key to welding imho.
The most important thing I've found about welding is to keep the rods in a dry place always, only taking out enough rods to get your job done. Many years ago, an old engineer gave me a tip about welding, i'm not sure even if its true but I keep it as a rule of thumb.... 1 inch of perfect weld will hold 1 ton of dead weight. For some funny reason, that fact always pops into my head as I am laying down a bead... I guess someone will come on here and rip that theory to shreds, but I thought I share anyway....
Heres another tip for you... If you haven't already got one, why not make your first project a welding table? I have one and would be lost without it. Mine is a little over 40" high which is a nice working height for me. The top is made from a solid sheet of 1/4 plate steel a little under 4ft square. It sits on a 1.5inch box iron frame. I have a vice bolted to it too which is handy... Nice thing about a welding table is you can attach your clamp onto the leg of the table and once you have your work piece on top of the table, it will make electrical contact. You can tack fixtures and jigs onto the table top and even attach magnets to the top to hold your work piece in position...
If you are having problems with your rod sticking to the work piece... maybe you could try pre heating the tip of the rod? Pull it across your work piece, the tip will ark as you pull it along. Once the rod tip is red hot, you will find it doesnt stick so much .... Of course you will have to clean that up after, but in time you will get the knack and not have to pre heat.
I'm teaching my daughter to weld at the moment, she is getting the hang of it too. She prefers using the mig over the arc though, if the mig sticks she just pulls the trigger, zaps the extended wire and carries on... (scares the be jesus out of me when she does it). When the arc rod gets stuck, she has to get me to cut the rod off...
Both of my machines have fans at the back and I let them switched on while I'm working.
/ Welding rods
Swines: So what does one do with the electrode holder after you've burned up the rods you had out and need to go open a canister to get a new set? I'm assuming I shouldn't just set it somewhere while I am puttering around? I'm also assuming that if I touch it mistakenly with bare hands (as a mistake) it will electrocute me (right?). I'm probably missing something basic here? Is the electrode safe so long as it is not touching the work piece that the clamp is on?
/ Welding rods
Blagadan:
Thanks for those good tips. I was able to pick up a nice welding table used. It's 72" by 28". Nice setup. Otherwise that was going to be my first project.
/ Welding rods #11
canoetrpr said:
Blagadan:
I was able to pick up a nice welding table used. It's 72" by 28". Nice setup..
Nice... Took me years of welding on concrete floor with aching knees before I figured I needed one!! You're starting off right!!!
Best of luck to you.
With my "electrode holder", I usually hang it over the handle on the front of the welder to stop it from coming into contact with the piece when I'm done.
There is a risk of electrocution if you "complete the circuit", i.e., you hold onto the ends of both electrodes... Even though it is low voltage, you will probably get a shock. Newer welders are safer in that respects, by, I remember my dads old ac welder, you get a belt off of that machine, you would feel it...
If you are concerned about welding, heres an interesting link.
http://www.ic.polyu.edu.hk/new/Facilities/d3/ee/KennethReport2k0208.pdf
/ Welding rods #12
What the heck, let me throw in a couple things.
6010 = DC, deep penetration rod
6011 = AC deep penetration
6013= AC low penetration rod
7018 = (normally a DC rod but some AC available) High strength (the 70 is that many thousand PSI so it is 10,000 PSI stronger then a 60 series rod properly applied) The biggest things learners do wrong with 7018 is they cannot restrike the rod. It forms a bead of glass slag on the end when you stop, you have to STRIKE, as in hit, as in tap it on the steel to break that glass end, and restart your arc, after the first if you do not draw an arc, you can then scratch (like a kitchen match) start.
7014 = AC fast fill, fast Freeze.
Everything is a trade off, and you look to get the charachteristics that are most important, deeper penetration is a trade of with surface looks and splatter, etc. etc.
My suggestion, if you have clean steel to practice with
6013, on AC and spend an hour a night running beads for a week. Stick to one size rod (1/8") vary your heat a bit up and down, I would probably burn that about 100, a general rule of thumb is convert the rod diameter to decimal ie a 1/8" would be .125 and run that many amps, ie 125 amps. I usually run colder then that. That will vary between welders, and Weldors as well as different makes and types of rods.
Most farm stuff, I would reccomend 1/8" 6011 on AC, not the popular thing on this board, but hey, it is my reccomendation.
Just work the basics.
As to shutting the machine off. Quit.
as you gain experience, jerk the rod off the base when you feel it start to stick. If you do stick and you cannot wiggle off quick enough, realease the rod from the holder, then when it cools wiggle it off and go again, or start with a new rod.
Set your electrode holder down so it is not in contact with what is grounded, as someone said, hang it, set it on concrete or wood, or most are designed when no rod is in, that the electrode is surrounded by insulated material.
All is said and done, a quick Vo-tech course, or a buddy that is profiecient coming over and welding for an hour with you will greatly speed the learning curve.
Good luck.
/ Welding rods #13
the 6011 a size over the 1/8--I believe its a 5/32--works pretty good if you run a cutting torch like I do--wide gaps that need some fill. I use these on welding up pipe fence and works well for me. If you cut closer tolerances, then the 1/8. I am just a shade tree welder however, but that's been my experience with the 6011.
/ Welding rods
AlanB: What is the advantage of running the 6011 on AC vs. DC?
/ Welding rods #15
DC and 7018 rods to learn on. If you cant weld with that combo...you arent going to weld with anything. Not sayings its the BEST ROD for everything..or anything like that...but its what I FINALLY learned on and was sticking metal together within 10 minutes....after TRYING for more than 30 years with an AC welder!
/ Welding rods #16
Probably not an advantage, but more what I am accustomed too.
As a general statement, 6010 rods were designed for DC while the 6011 where the AC version, my belief (could well be wrong) is that most 6011 rod is optimized for AC work.
When working with AC you have the reversal of current (might be using the wrong terminology) but basicly your sine wave goes top to bottom, when it does that you tend to get some "freezing" of your weld, if you will allow me some latitude, it is almost a pulse, which sometimes helps new welders.
Oh, and far better then I can write, here is Lincolns electrode chart.
http://content.lincolnelectric.com/pdfs/products/literature/c210.pdf
/ Welding rods
I've heard mixed things about 6010 vs 6011 - on which is easier for a novice.
One opinion is that 6011 has flux stablisers which somehow makes run better. Another is that 6010 run smoother. Anyone have any thoughts on this?
I might as well pick up 1 lb 1/8 rods of each and give them a shot.
I'll pick up 1 lb of 1/8 7018 as well and see how I do with that.
I'm pretty confident at being able to run some nice beads with 7014 but I don't know what the penetration of it is like. Should be able to get something done with it though.
/ Welding rods #18
My take on it ,from personal experience for 20 years of welding jack of all...master of none:D
6013-easy to light,generally used for thin stuff,makes a pretty good lookin bead
6011[what i use the most of]best all purpose rod imo,makes nice bead,great for dirty rusty stuff
7018 harder rod to use,but will hold the best,i use for things i dont want to ever break loose .Icant remember... but i think its called high tensil strength,
Never heard of a 6010 up in this neck of the woods.Ithink once you get the hang of it youll use 6011the most,6013 for tacking stuff and thin,cause it lights easy.You will use 7018 only on occasion,like i said for super strong applications.If you build alot of stuff,tools etc,wear surfacing rods are available[i used them on my backhoe thumb teeth,they work well]
have fun!!
ALAN
/ Welding rods #19
I been maintenance welding for 30 years and I finally threw out all my 60 &70 series rod and now just use MG 500 or 600 for everything, except cast iron.
/ Welding rods #20
Ive never heard of them,can you tell us more?
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
2013 BIG TEX T/A UTILITY TRAILER (A67714)
2013 BIG TEX T/A...
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
PORTA POTTY (A67714)
