Welding Respirator Question...Help ?
/ Welding Respirator Question...Help ? #21
If I just wanted something to wear while welding in the garage, I would get a 10 - pack of 3m 8515 disposable welding respirators they would be about $2.50 each. have a flame retardant outer layer and are N95.
/ Welding Respirator Question...Help ? #22
It also depends on how bad you have been exposed to it and your personal health situation. I have been using a good 3M half mask for grinding and plasma cutting, but it doesn't fit under my Miller hood. I did a stupid this past weekend. Because of the cold I only opened my roll up doors halfway and set my fan on low (24x36x12 shop with 10 ft roll ups on each end). Only spent two hours welding but wife noticed a little smokiness. I have had the welding fume fever for 3 days. Headache finally dropped down to "normal" migraine levels this afternoon. Still have the muscle aches, joint pain, projectile vommiting and diarrhea.
Doctor is still deciding if I should giveup welding completely due to this incident and my other health issues.
Anyways, take it for what it's worth...?
Ps. Flux core welding on unpainted channel iron.
/ Welding Respirator Question...Help ? #23
man, you should really try Hobby Air Respirator 40' Hose / Air Supplied Hood: Amazon.com: Industrial & Scientific
mind you, you can find these on ebay for lost less $$$
not worth 3 days of suffering . These units pipe in fresh outside air (40-50 feet away)
when i use mine i cant even smell paint fumes when spray painting. it works wonders
/ Welding Respirator Question...Help ? #24
man, you should really try Hobby Air Respirator 40' Hose / Air Supplied Hood: Amazon.com: Industrial & Scientific mind you, you can find these on ebay for lost less $$$ not worth 3 days of suffering . These units pipe in fresh outside air (40-50 feet away) when i use mine i cant even smell paint fumes when spray painting. it works wonders
Looks like a good unit but about 8X the price of an APR setup.
All of these respiratory protection devices should be fit tested to your face.
They also don't work with facial hair
Sent from my iPhone 5s 64Gb using TractorByNet
/ Welding Respirator Question...Help ? #25
well, i dont have facial hair. On mine i can disconnect the air supply line and try to breath in...i get no incoming air flow.
I paid $210.00 new for mine on ebay 4 years ago. Never regretted it.
MF GC2300 fel replaced
CAT 963 4-in-1 Bucket (A68134)
CAT 963 4-in-1...
1996 DODGE RAM 1500 LARAMIE SLT EXTENDED CAB TRUCK (A65057)
1996 DODGE RAM...
86 (A63290)
86 (A63290)
Caterpillar D330 4 Cylinder Power Unit (A64912)
Caterpillar D330 4...
THERM DYNAMICS TD 375 FLAMELESS HEATER (INOPERABLE) (A68842)
THERM DYNAMICS TD...
