welding question
/ welding question #41
Wow...so much testosterone...so little usable information.
I have a 300 amp multi-process machine setup for MIG, a 185 Amp TIG, and " 'lil sparky" - a 140 amp dedicated stick machine.
Now, why do I have all of those machines.....hmmmmm...maybe one process isn't the best for everything?
How about, you just make the correct joint preparation - and do the best with the machine you own? We do about 85% MIG, 10% TIG, and 5% stick.
If needed, the 300 Amp multi-process can get turned into a stick by flicking a toggle switch to the left and replacing the MIG gun with a stick stinger - I've never had to do that.....as the MIG is one pass using 1/16-inch wire on metal up to 1-inch. Waaaay faster than stick as the deposition rate is so much higher.
Sometimes time = money...but it helps to know WELD JOINT PREPARATION....
/ welding question #42
Ah c'mon man....a 300 amp 1/16 is a FAR cry from a Hobart 140.
Let's compare an Electra-glide to a Honda 50. Sheesh.....
2014 Bayliner 180 Boat with 2004 Venture 24ft T/A Boat Trailer (A59231)
2014 Bayliner 180...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1999 John Deere 7810 (A60462)
1999 John Deere...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2005 John Deere 7320 (A60462)
2005 John Deere...
