welding on the tractor
/ welding on the tractor #22
Didn't read all replies so apologies if this duplicates other's advice. It's always a good practice to disconnect battery prior to welding because of transient current that can run through wires and, sometimes, even steel reinforced hoses.
If your machine has any computers, micro processors or digital devices, it is CRITICAL that you disconnect the batteries to prevent damage to those items from stray current induced by welding.
Good luck.
/ welding on the tractor #23
I thought I remembered hearing that the battery buffer/smooth out the electrical spikes of welding rather than going straight to the electronics/computers. I think you would have to disconnect all grounds as well as the battery to really isolate the electronics.
FWIW Off the top of my head I have welded on all of the following without disconnecting the battery 1980 Scout, 97 GMC K3500 6.5TD, 2006 NH TC45DA and 2020 Ram 2500 none have been damaged by it.
I do place the ground clamp as close to the welding as possible.
/ welding on the tractor #24
If your tractor is newer with computer, by all means disconnect pos and neg cables. My 2000 Kubota does not have computer and I have done lots of welding and no battery disconnecting and no problems.
/ welding on the tractor #26
Candidly, I never disconnect the battery on anything when welding. As long as you put the ground clamp as close to the part being welded and the metal where you place the ground clamp is clean and bright, the chances of stray currents are almost nill.
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
Wacker PT3 Water Pump (A65640)
Wacker PT3 Water...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
