Welding on 55 Gal Drum
/ Welding on 55 Gal Drum #1
dieselscout80
Veteran Member
South Carolina
New Holland TC45DA
I want to weld some skids on my 55 gallon drum for diesel fuel. The skids would allow me to put a drain in the bottom so the drain, pipe and valve wouldn’t get damaged.
However, if I weld on the bottom rim will it leak afterwards?
/ Welding on 55 Gal Drum #2
Will the drum be used upright or on it's side normally? If it's on it's side, I would bend some flat bar and plug weld it to the thin material and tack it pretty good to the rims. Put all your runner supports and tow points on the heavier material. The plug welds will keep you from blowing out the thinner stuff and seal any pinholes. Don't drill too big of plug holes. I just did something similar to this on the Bobcat muffler, it had a couple of holes and that seemed the best way to patch them.
It will be vertical always unless there’s an oops and hopefully that won’t happen.
Will the drum be used upright or on its side normally? If it's on its side, I would bend some flat bar and plug weld it to the thin material and tack it pretty good to the rims. Put all your runner supports and tow points on the heavier material. The plug welds will keep you from blowing out the thinner stuff and seal any pinholes. Don't drill too big of plug holes. I just did something similar to this on the Bobcat muffler, it had a couple of holes and that seemed the best way to patch them.
I hadn’t thought about plug welding.
/ Welding on 55 Gal Drum #5
I haven't welded on one. However, I'd probably choose to stay away from the rim if at all possible. Otherwise you could be chasing your tail trying to get it sealed.
It might be OK, or it might not be OK.
You could weld angle iron pieces to the side of the barrel, or chunks of bar steel to the bottom away from the rim.
/ Welding on 55 Gal Drum #6
Anything flammable in the drum from before or is it new? You don't want to end up on the news from lighting an arc with flammable vapors there...
/ Welding on 55 Gal Drum #11
Why not build the skid, set drum on it and clamp it with long rods (with turnbuckles) from skid to top of drum... No danger of blowing holes in drum
That'd be my way of doing it. Being a weldor by trade, I'd never weld to a drum because of the possibility of causing leaks, maybe not right away but later caused by flexing of the tank. Good cradle/stand and clamp it.
/ Welding on 55 Gal Drum #12
Plug weld it. I've done it many times on car panels and many other things including drums.
/ Welding on 55 Gal Drum #13
I don't know about welding a spigot on the side, drums are pretty thin.
However you might try brazing it on with a torch, I think it would seal better.
However I'm with Mr.mikey on this one, just clamp it to a stand....
/ Welding on 55 Gal Drum #16
I just use hardwood pallets for storage, I can use forks to load onto truck to refill, a simple hole saw would make a hole for your drain
/ Welding on 55 Gal Drum #17
The rim is folded over (thick) enough to weld some rails to it.
The drum itself, when i wanted a burn barrel i used use the stick welder as a thermal lance to burn the endplates out. Thickness of a barrel is really nothing..
FENCE PANELS (A58214)
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2017 Ford Transit 250 Cargo Van (A59230)
2017 Ford Transit...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2002 Blue Bird F131612 Bus (A59230)
2002 Blue Bird...
