Welding on 55 Gal Drum
   / Welding on 55 Gal Drum #11
Why not build the skid, set drum on it and clamp it with long rods (with turnbuckles) from skid to top of drum... No danger of blowing holes in drum
That'd be my way of doing it. Being a weldor by trade, I'd never weld to a drum because of the possibility of causing leaks, maybe not right away but later caused by flexing of the tank. Good cradle/stand and clamp it.
   / Welding on 55 Gal Drum #12
Plug weld it. I've done it many times on car panels and many other things including drums.
   / Welding on 55 Gal Drum #13
I don't know about welding a spigot on the side, drums are pretty thin.
However you might try brazing it on with a torch, I think it would seal better.
However I'm with Mr.mikey on this one, just clamp it to a stand....
   / Welding on 55 Gal Drum #16
I just use hardwood pallets for storage, I can use forks to load onto truck to refill, a simple hole saw would make a hole for your drain
   / Welding on 55 Gal Drum #17
The rim is folded over (thick) enough to weld some rails to it.
The drum itself, when i wanted a burn barrel i used use the stick welder as a thermal lance to burn the endplates out. Thickness of a barrel is really nothing..
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
NEW Woods 6ft Finish Mower (A52748)
NEW Woods 6ft...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
