welding mild steel to a replaceable cutting edge
/ welding mild steel to a replaceable cutting edge #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
I made a landplane out of mild steel, 1/4" wall thickness, and noticed today that several of the welds were separated from the cutting edge and the angle iron. I am using a smaller Miller but still, 220 Volt unit, had it cranked up, and made several 6-8" welds across the length. I can see where I had plenty of penetration into the cutting edge but they are all breaking loose. Is this a lost cause? I did this once before on a grade blade but the forces on the welds were different so I assume that is why it never failed.
preheat the cutting edge with a torch help?
/ welding mild steel to a replaceable cutting edge #2
Pre and post heat would help. Are you using wire feed? For this job a stick or TIG welder would be better. That's because then you can buy the right alloy filler metal for the job. Welding rod with a high nickel content is good for this type of job, but even stainless steel rod would probably work. You could run stainless wire in a wire feed with argon gas. It would look crappy but might work. Some hardfacing wires might work too. But they are expensive and you would need to choose a ductile hardfacing wire, I don't know the specific alloys but there are some.
Eric
/ welding mild steel to a replaceable cutting edge #3
Can you post a picture?
/ welding mild steel to a replaceable cutting edge #4
I would bolt it on.
Is your angle still an open-sided angle, or is it now a sealed triangle?
Bruce
/ welding mild steel to a replaceable cutting edge #5
If you weld with some 7018 with a stick welder set to 125 amps, I can tell you this: The metal will break before your welds do.
/ welding mild steel to a replaceable cutting edge #6
To be sure we clearly understand what happened,are the welds pulling away/seperating from parent metal? If that's true you either used an unsuitable filler (wire or rod) improper gas if mig welding or you did not get good penitration. Most commonly available rod is ok for mild steel (6010-6011-6013-7014-7018-7024). Flux core, Solid wire and gas doesn't cover wide ranges for each type so choose only those reccomended for each application. An easy mistake is multi passes with single pass wire. That can trap slag and weaken bead.
If beads cracked the problem can come from a number of issues. I'm betting a couple close up pics will alow our more experienced members to get you on the right track.
I will grab a couple of close up tomorrow. I used a Milllermatic 211, .033 wire solid core wire, on a 75/25 bottle. the bottle says "UN1956 Compressed gas, N.O.S. (Argon, Carbon Dioxide).
The metal did break before the welds, there are deep penetration holes that are consistent, weld held fine on the mild steel angle.
From the descriptions above sounds like it's getting bolts. I do not have access to a stick machine, remember 20 years ago using maybe a nickel rod to weld cast iron (decorative) to fence posts.
/ welding mild steel to a replaceable cutting edge #8
Yeah, if you can drill the blade it looks like the best solution for you at this time. You are probably using 70S6 wire. C25 gas mix, which you are using, is correct for this wire. Since the welds are not breaking but instead the blade is breaking in the heat affected zone, this tells you that your welds are good but the procedure and/or the filler wire alloy is wrong. You could try some stainless wire with your C25 gas mix. The welds will look really bad. It may hold. You can buy small a spool of SS wire meant for a spool gun or a smaller welder and try it, but if you can drill the blade then do it.
Eric
/ welding mild steel to a replaceable cutting edge #9
Ive used cutting edge steel for several projects because we keep em around after theyre worn down at work and have had the same problem in the past. Im no metallurgist, but I think the issue comes from the cutting edge being so hard that the contraction of the weld causes an extremely pinpoint stress riser at the penetration edge that starts the formation of a crack. I found preheating solved my issue completely. I cant guarantee we're using edges made of the exact same stuff but i'd recommend preheating.
/ welding mild steel to a replaceable cutting edge #10
I welded a road grader blade on a tractor bucket. It gets used regular and hard. Built a fire under it in half a drum. Heated and welded with 7018.
/ welding mild steel to a replaceable cutting edge #11
Don't waste your resources trying to run SS mig wire with straight Argon. 0 chance of working. Buy a pound of Weldcote Super 120 stick rod. If there is any left over you can use it to weld the leaf spring on your Jeep. 7018 will also work and is common for this repair. Good Luck..
/ welding mild steel to a replaceable cutting edge #12
From the OP, post#7 - "I do not have access to a stick machine"
I've not had occasion to try it, but supposedly 70s wire is considered low hydrogen - so it seems to me that finding a way to preheat might be the only option.
I have a few grader blades, local county shops used to GIVE 'em away. Don't think I'd wanna drill that material without a "gas axe"... Steve
it was a bolt-on edge before, it will be again. there are several pre-drilled holes. I will grab my calipers and figure out what I need.
It was a new problem to me, welded every day as a young man then figured out another way to make a living, have the MIG now for light fab, repairs and this dang gate the CFO wants me to build.
Thanks, Guys.
/ welding mild steel to a replaceable cutting edge #14
If your pre-drilled holes are like the ones on my stash of used grader blades, they're pre-formed/punched for plow bolts - those present a smooth flat top and have a square shoulder (like a carriage bolt, but with a flat topped head) - if your blade has that, I would DEFINITELY find some actual plow bolts... Steve
/ welding mild steel to a replaceable cutting edge #15
We used 6010 on the inside of a large crack and then 7018 at around 115A on the crack itself after grinding the Vs everywhere needed on my payloader bucket. It is still holding.
/ welding mild steel to a replaceable cutting edge #16
Hard to use those with a Millermatic 211......
/ welding mild steel to a replaceable cutting edge #17
Try to preheat and cool slowly thats your best bet short of a stick machine and some stainless like a 308l
/ welding mild steel to a replaceable cutting edge #18
We used 1/8" rods with my humble Miller Multimatic 200 which is a fantastic little welder.
/ welding mild steel to a replaceable cutting edge #19
/ welding mild steel to a replaceable cutting edge #20
All of which is a moot point if people would actually READ the OP's last post #13, and quit trying to drive traffic to their U-tube channels and/or brag about high dollar equipment they KNOW the OP does NOT have... Steve
