Welding galvanized: precautions?
/ Welding galvanized: precautions? #11
Unless you are SUPERMAN wear a mask!:D :D :D
Supermen are hardy folk who die before there time for some unknown reason:D :D
/ Welding galvanized: precautions? #12
/ Welding galvanized: precautions? #14
OK, here's some info for you guys to read up on about Metal Fume Fever. Took me a while, but I finally found it...
It is NOT cumulative.
It is NOT deadly.
It is very uncomfortable, and you certainly don't want to breathe any more zinc oxide fumes than you have to... but if it unfortunately happens, you'll be OK, you won't grow a third eye or anything, and you certainly are not going to die. It takes quite a bit more than a breath or 2 to get the 'fever.
  • MetalFumeFever.pdf
/ Welding galvanized: precautions? #16
Egon said:
Yup: I am trying to say something!
Wear a mask!
That's like saying Wear a helmet! when painting.
The only time I wear a mask is when welding around dry cleaning equipment.Perclorethylene produces phosgene in a arc.
/ Welding galvanized: precautions? #17
Overblown. You're not supposed to be inhaling any welding fumes. You certainly will inhale a little bit and you will be fine.
Note that welding on the galvanized stuff is a little tougher since the burning zinc emits gasses that are not shielding gas. It makes a pretty green puddle though. Like paint, once your arc is established and hot the rest of the weld goes well.
/ Welding galvanized: precautions? #18
This reminds me .Check out anvilfire.com go to iforge ___saftey __metal fume poisoning__sad story. Check out the terrific projects while you're there.
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
2017 Komatsu PC138USLC (A60462)
2017 Komatsu...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
