Welding cost
/ Welding cost #61
I think what some are failing to think about here is that, sure to lay down a 160" of weld is no big deal and shouldn't take any time at all. I've done bucket repair, you have to make sure the parts aren't going to move around even on a 15" bucket. I've cut off cutting edges and just threw the bucket up on the bench and welded it back together and the cutting edge looks like a taco. So there has to be some planning. The bucket has to be secure, if you want the pins to line up you are going to have to make some jigs, you can't just pull the trigger and stop 160" later and expect everything to be the same shape it was when you started. I'm sure JJ's friend knew he expected a certain level of skill and competence and that's what he got, and also got a bill that reflected that.
/ Welding cost #62
I think what some are failing to think about here is that, sure to lay down a 160" of weld is no big deal and shouldn't take any time at all. I've don bucket repair, you have to make sure the parts aren't going to move around even on a 15" bucket. I've cut off cutting edges and just threw the bucket up on the bench and welded it back together and the cutting edge looks like a taco. So there has to be some planning. The bucket has to be secure, if you want the pins to line up you are going to have to make some jigs, you can't just pull the trigger and stop 160" later and expect everything to be the same shape it was when you started. I'm sure JJ's friend knew he expected a certain level of skill and competence and that's what he got, and also got a bill that reflected that.
Touche'
/ Welding cost
I am realizing that some of you charge really high prices for your work. Maybe your part of the country can handle it.
He was not kind of a friend that would give discounts, I didn't ask for one either. I just knew him from previous jobs and what he charged for those other jobs.
The bucket welding price was a really big shock.
I think some of you have a really sad outlook on what is fair. I usually pay the going rate , but I usually know a rip off.
Some of you don't read well either, I said I could weld but wanted a good job done. He had done welding for me before.
I did not take the bucket to him because I could not weld, I wanted a good job done mainly because it is difficult for me to see very good even with magnifier inserts in the helmet.
Some of you made excuses for him for various reasons. Perhaps because some of you operate that way.
Most of you should know when you are taken advantage of. If you cruise the internet, you can see what welders are charging in different parts of the country.
How can any of you blame me for what happened. I know I was over charged.
This was long ago, but was just an example what could happen. I was wanting to get an idea of the prices some of you charge.
I am finding out it is very subjective, mostly just charge what you want.
There is a good bit of difference in friends and customers, they just are not treated the same.
I don't believe I have ever seen a welding price list anywhere.
Always get an estimate, I must always remember that is what I usually tell everybody.
Lastly, I treat good friends with respect, they make life better in all things.
/ Welding cost #64
Certainly not to be taken as a criticism of JJ because his posts are usually balanced, but merely an observation of fact. What is missing from this discussion is the point of view of the welder - why did he charge that much? I don't doubt JJ believes he was overcharged, and maybe he was. But maybe, just maybe, he wasn't. Till you hear the other side it is difficult to judge. The good lesson is: get an estimate.
I have had the opposite experience with a welder that does commercial fabrication (that is, doesn't normally do odd jobs). I took an alloy telescope base to him to fix a large crack. He told me it was really difficult to weld that alloy without causing another crack. I told him I understood and asked him to try. I was shocked when he charged me only $20.00 for the repair.
/ Welding cost #65
Welding the eyes for the pins would be the last step for me. I can't ever think of a time I welded up something by starting at one end and welding to the other. I'm a big believer in back stepping, skipping around, and monitoring the object with a square and tape measure. Even tho the odds are hugely stacked in my favor I can bring an object back in line by heat shrinking. But that is time consuming, and I just soon avoid having to do it.;)
/ Welding cost #66
Obviously, we're all wrong.
There's a saying that friends and family make the worst customers. This is a prime example.
You've been given numerous reasons why you probably weren't over charged, but your mind is made up. What's worse, you expect a discount from friends. Something tells me this isn't the only example you could cite of being "ripped off" by friends in business, and this friend knew exactly what he was doing. Good for him. Some customers aren't worth the head ache.
/ Welding cost #67
That was my point. There has to be some thought and preparation, and likely some jig making of some sort.
Now week before last I had a customer with a Bobcat that had worn out the tapers on the boom for the lower Bobtach pins. The only way to fix this is to cut out the old tapers and weld in new bushings from Bobcat. I quoted the customer 6 hrs., I wish it didn't take that long but from experience it does and I've done several but not the same model as my customer's machine. He thought my quote was a little high and decided he and his buddy would do it themselves. I understood, sometimes I don't get every job I estimate. So on a Sunday I get a call, hey Brian we can't find where the bushing is, we can't find a parting line, my buddy is afraid to do this. So I went to his place a couple of days later and was surprised to find that there was no bushing that was welded in, the taper was actually ground into the arm. I was even nervous about doing it now, I called my mentor who came out and basically told me not to be a wuss and to go ahead and cut a hole in the arm and weld the new bushings in. So I did, because of my apprehension, it took over 8 hrs instead of the 6 I quoted. I handed my customer a bill for 6 hrs. plus materials and he added a $100 to it because he knew it took more than I had counted on. He was impressed with my work and that I called somebody when I was stuck. He was very glad that they stopped when they did. He also appreciated that I stuck to my word.
/ Welding cost
You in particular are so very wrong in your application of the facts.
/ Welding cost #70
JJ: Did he give you any reason at all why it costs so much.
I think that is what we are after here. We are only getting your side of the story. All we know is.....15" bucket, already tacked, and he tried to get $350 from you.
BUT, did he only have to weld everything?
OR..... Did he have to make jigs? Did he have to take it back appart?
You obviously questioned the $350. Thats how you got him down to $325. But if it truly was a $350 job, he should have given you a good reason for why he charged that much.
Throw us a bone here:thumbsup:
/ Welding cost
I really don't have an answer why he charged that much. Must have been a slow day and he did not make his minimum.
I often wonder if I had ask him to build me a 15 in bucket if he would have charge me upwards of $1000.
All the parts were fitted and tacked.
He only mentioned time to weld and consumable cost. He said something about shouldn't be that much when I asked for how much and how long.
I guess THAT MUCH is very relative as to the level of expectation, with me expecting less and him more. I think now that I should have thrown out a figure, if over xx dollars, give me a call .
You usually trust people until you can't trust people.
Here is a similar example.
My friend took her car in for service, and they did the service, but they also told her she had a serious oil leak on the engine and all the seals on the engine would have to be replaced. The estimate to fix the so called oil leak was in the $1400 range. Of course she did not like that at all and she said she did not want to put that much money into the car. I told her they were trying to take advantage of her, as I knew the car, and the area where she parked had very few oil drops in the cement. She went on to purchased a new car and I offered to buy the car and she agreed. I have driven the same car for about 8 years, and it still does not leak.
Some of will ask why someone would do something like that, money is the answer of course, and they are part of the low life in this country with few morals.
To the people that do these kinds of things, it might just come around and bite you in the a**, just when you think you are doing so good.
/ Welding cost #72
I can't speak for what he should have charged you for his time, but as a contractor, my living is based on what I charge others. I have friends and family members who want me to do things for them and then ask for a discount in my rates. I explain to them that my rates are what I feel my time is worth, and that I will make that amount working for somebody else. Doing it for less means that I'm losing money, or it's costing me money.
I will do a favor for free and enjoy doing it, but if they want to hire me to do something and I take the time to do it, I will give them the very best job possible and go out of my way to make sure it's what they want, but I'm going to charge what my time is worth.
Eddie
Exactly.
I have always maintained the best relationship with friends when, in the course of doing business, we charged one another the going rate. Sometimes money changes hands, sometimes there are other considerations that constitute payment. When I farmed, I was (and still am) good friends with brothers who farmed nearby. We would supply manpower and equipment to each other a few times during each season when it was necessary for one and possible for the other. We charged each other just like we would any other paying customer, except we settled up once a year. Surprisingly little money changed hands, and we remain friends to this day.
Getting stuff done at a cut rate by playing the friendship card usually plays out the friendship. A friend truly in need will get my help with no strings attached.
/ Welding cost #73
I was willing to pay a fair price, but how long does it take to lay down 160 in of weld.
The only work he did was weld 160 in. How long would it take any you to lay 160 in of weld? I don't think he used any special rod on the bucket.
I have seen a lot of small jobs go in and out for about $40 and about 20 min. That is about $120 an hour.
Some of you guys are hard line, and I hope you don't treat all your friends that way.
There is nothing wrong with saying would you mind paying for the consumables or the going rate for labor, and the estimate is .
I have done many many free jobs, because I wanted to help some out with a difficult problem.
I have heard these words many times, can you help me. I have never said, can you pay.
Sometimes you have to lower the friend ship level on those that take advantage of you.
Someone mentioned me and a problem that I had with book labor and actual time. You still have to question , just what is fair, and it is not hard to do if you know a little something about the subject.
Bottom line, a true friend knows how to separate business from friendship. If you weren't concerned enough about the cost of the job to ask about it in advance, don't ***** about it after the fact.
/ Welding cost #74
I'd wager that JJ asks all the time now. :laughing:
I have an ex-friend I used to work with. On one of his jobs I was doing some plumbing at his desperate request. I told him we knew the valve on the main was leaking bad, we weren't plumbers, and if it goes wrong we'd regret it. His answer was 'we have to get it done now'. Of course two weeks later, I get the call, and say OK, I'll pack up, leave my job and go fix his job 50 miles away, and I do. Took me about 7 hours all told. Well I wanted to get paid something, since I'd told him not to try it. I think I asked him for $135. No deal, and we haven't spoken in 3 years.
/ Welding cost #75
Exactly.
When I was married, my father in law would really try to get me to feel sorry for him and remodel his master bathroom for him for free. He told me how he just didn't have any money to do it, but the shower leaked real bad and he didn't know how to fix it either. At first, I felt for him, but was too busy to do anything. I offered to help him out in the evenings if he'd do the demo work. He put that off one week after another. Turned out he wasn't busy, he went fishing. That annoyed me, so when I finished the job I had been working on, I went right on to the next one. A couple months later, I found out he bought a brand new pontoon boat. In the years that I knew him, and was married to his daughter, he never invited me out on that boat.
Eddie
/ Welding cost
Apparently you can't read either.
I also said I only knew him as a working friend.
Read my previous post.
Come on now Rick, you know you got taken advantage of and probably got screwed over more than once. I will bet you whined and bitched just a little. Own up to it.
/ Welding cost #77
I would take comfort in the fact that I bought a little old Ladies car.
/ Welding cost #78
Eddie
I wouldn't either....unless you wore a hat. The sun reflecting off that hairless head scares the fish away...................:laughing::laughing:
/ Welding cost #80
JB Weld. Easy and cheap. :laughing: Just kidding although that is what I would do if it were my own.
2023 TAKEUCHI TL10V2 SKID STEER (A65056)
2023 TAKEUCHI...
2018 Ford Escape SUV (A66738)
2018 Ford Escape...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2015 Keystone Fusion (A64912)
2015 Keystone...
2009 FORD CROWN VICTORIA (A66091)
2009 FORD CROWN...
2018 Ford Explorer AWD SUV (A66738)
2018 Ford Explorer...
