welding AR500
/ welding AR500 #1
crazyal
Super Member
Northern Vermont
Kubota, Case, Deere
So we had another thread not long ago about welding gun targets but it really didn't tough much on how to weld it while doing as little damage to the hardening as possible. Here's what I would like to do. I have a couple 10" gong style targets made out of 1/2" AR500. They are fun to shoot at openhanded at 100 yards but offer no challenge to a scoped rifle. What I would like to do is cut a 2" out of one and 3" circle out of the other in the center. I've seen targets that have a smaller piece of steel in the center (see picture below). What I would like to do it make the center piece of steel fall back and disappear and another target show up below the main target. Cutting the hole would be easy with my plasma cutter but I would either have to weld some sort of bracket to the back of the target or possibly drill holes and use grade 8 bolts to mount what ever design I come up with. I'm wondering if I preheat the steel and make short beads, say 1/2" long, allowing the metal to cool between each weld if that would be still too much.
I have thought about putting the center target on a rest of some sort so when it's hit it would fall off the rest. If I use long chains once knocked off the rest it would then hang below the main target. Another option would be to make something out of mild steel that bolted to the back of the target using the two holes already in the target for the chain. It would be more complicated but the AR500 plate would be in front of it to protect it. It might be kind of neat if I made some sort of mouse trap design where a spring loaded target pop out on each side after hitting the center target. I'm not sure what will happen if I make the target too heavy though.
/ welding AR500 #2
Is AR (abrasion resistant) the same as hardened? I'd like to know how to identify it. Like by spark color or something.
/ welding AR500 #3
Yes welds just the same as carbon just got done welding a pile of it at work recently. Only downside is the HAZ (heat affected zone) is permanently annealed so the trick is to make smaller quicker welds and use a multipass technique with plenty of cooling time between passes.
/ welding AR500 #5
Actually AR = Abrasion Resistant, not armor. It is hardened stuff...
/ welding AR500 #8
As a blacksmith I have to ask is it hardened or is it a steel that can be hardened. Most steel is shipped soft so you can work on it and is hardened by the user. If you know the formula and have the equipment you could harden it after welding. Ed
/ welding AR500 #9
It comes hard it's not a tool steel this comes in big sheets up to 20'x40'
/ welding AR500 #10
Correct... and the 500 is the hardness rating (Brinell). Very hard stuff. I believe originally developed for the mining industry, mainly the ore chute liners. Makes good but heavy armor too. Not as fun to weld to weld from what I understand, at least this is what my customers tell me.
/ welding AR500 #11
Seems as I remember the welders in the Navy yard telling me they use a lot of HY-80 for armor plating.
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
CROP CARE PLASTIC PLOW / LIFTER (A63291)
CROP CARE PLASTIC...
TAYLOR 24 BLADE OFFSET DISC HARROW (A63291)
TAYLOR 24 BLADE...
