Welding a nut into thin-wall steel
/ Welding a nut into thin-wall steel #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Here's a way I figgered out to weld a small nut into thinwall (3/8 nut into .065") steel tubing.
Drill a hole about the size of the wrench. For example for a 3/8" nut, which uses a 9/16" wrench, drill a 9/16" hole.
468887d1463463603-welding-nut-into-thin-wall-nut_thinwall1-jpg
With a cold chisel, cut the six corners
468888d1463463603-welding-nut-into-thin-wall-nut_thinwall1-jpg
Pound the nut into the hole flush, and weld it up.
468889d1463463603-welding-nut-into-thin-wall-nut_thinwall1-jpg
Sorry forgot to take a pic of it welded and now it's all "somewhere else". But at this point you know what to do.
/ Welding a nut into thin-wall steel #2
I'm too lazy. :)
What I would do:
Light duty-weld a T-nut into the hole.
For heavy duty, I would double-nut it on the end of a bolt, grind the nut round, then weld it into the hole
Bruce
Cutting those six corners is easy, fast. And it holds the nut for welding. Agreed, chisels are old-school. :) The only thing about this method that might be a challenge is drilling the right size hole.
For a 3/8" nut I don't think you want to grind away any metal, you need all you can get. I found a finished pic.
/ Welding a nut into thin-wall steel #4
Sodo
Thanks for the tip might just come in handy some time. Ed
/ Welding a nut into thin-wall steel #5
Thanks for the tip,I'll give this a try next time I need to weld one up.
Here's a pic of where it's used. It's for a wingnut to hold a spreader to prevent bending the cutting edge on a "bucket spade". Bucket spade is just 7" channel with some brackets to be held on by a cargo strap.
468920d1463501138-welding-nut-into-thin-wall-bucketspade1-jpg
Spreader bar slides in behind the bucket spade and there's a hole in the channel for the wing-bolt.
468921d1463501138-welding-nut-into-thin-wall-bucketspade1-jpg
468922d1463501138-welding-nut-into-thin-wall-bucketspade1-jpg
/ Welding a nut into thin-wall steel #7
Unless there is some reason for the nut to be counter sunk, I would have just welded around it while it is setting flush on top of the channel. I have welded hundred of nuts onto steel and pipe this way and never had a problem with the threads or the nut breaking off.
Gary I've done that too but this application is a thinwall sq tube.
I could have reversed it where the nut was external on the 7" channel (the spade) and wingbolt tightened from inside the bucket. But I have a 9/16" holecutter & (rotabroach) which is high technology modern tool on a battery-powered drill so had to balance it with an old-school hammer & chisel. :) Can't really call the MIG part modern technology. Hard to believe I learned to MIG on the farm in 1980 (36 years ago). :shocked:
/ Welding a nut into thin-wall steel #10
The riv-nuts would have to be installed from inside the tube to keep it from pulling out, and might wallow out its mounting hole in this application.
I've always rounded nuts off in the drill press with an angle grinder to put in tubing, or if there are a lot of them, I've welded nuts on a thin strip of flat bar and positioned it inside the tube and secured it with plug welds next to the bolt holes. That works quite well on something that is already finished, as the small plug welds cause less finish burn.
/ Welding a nut into thin-wall steel #12
Looks good to me. Nothing wrong with a novel approach in my book.
gg
/ Welding a nut into thin-wall steel #13
Anyways. For serious load transfer like the coupler of my trailer to the 2 by 4 inch tubes, i drilled 13mm holes for the bolts on one end, and 20mm on the other so i could put some sleeves around the bolts, welded on the end where the big hole was. This way you can tighten the bolts properly without denting the tube, or getting so much spring action that the bolts run loose
/ Welding a nut into thin-wall steel #14
Riv-nuts come in 2 styles.
Plain and then the better style that need a small key way (or notch).
The riv-but then has a dimple that fits the notch.
We used the notch style a lot in thin aluminum on aircraft.
In fact I still have a set of 4 notch cutters as well as the pullers in my tool box.
The largest is 1/4" and the others 6, 8, 10 X 32.
/ Welding a nut into thin-wall steel #15
A round hole has far greater integrity than one with squared or jagged corners.
/ Welding a nut into thin-wall steel #16
gg
Ditto! I agree with Gordon. Gotta love any new idea that can be added to one's repertoire. Thanks for sharing Sodo! :thumbsup:
/ Welding a nut into thin-wall steel #17
While I agree with that it won't matter much once it is welded up.
/ Welding a nut into thin-wall steel #19
It's just thin wall...just how high a load are you going to run on that?
I suspect any load situation where this setup is not sufficient will run into structural problems with the _rest_ of the tubing long before it is an issue.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2017 PETERBILT PB337 HYDRA-TAIL FLATBED TRUCK (A59823)
2017 PETERBILT...
2022 NIFTY TM34TE-MK1B TOW BEHIND BOOM LIFT (A60429)
2022 NIFTY...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
