Welder Selection Help
   / Welder Selection Help #21
my linclon 220v 135 says you can weld 1/4.It doesn't do that great of a job on 1/4 so I leave a small gap to get better penetration. I don't know what size the welder you are getting ,but from the price it sounds about the same size. I wouldn't trust mine to hold 1/2 .
   / Welder Selection Help #22
Guys; The way I'm reading everyones posts, sounds like there is quite a number of guys expecting to weld in one pass. /forums/images/graemlins/confused.gifDid I read this right? I was taught on thicknesses greater than 3/16", you should expect to weld in mutiple passes whenever possible.
Also, to use square groove, or V groove technique. Burn in your root pass with 6010/6011, then cover passes with something like 7018. Tell me if I'm wrong. /forums/images/graemlins/grin.gif
   / Welder Selection Help #23
Dan,
I would agree that you need a stick welder. If your going to make tractor toys you will want decent penetration into the metal that a low cost wire feed probably won't do. Stick is very versitile. Check out the rod selections for various metals and tasks. I have a Miller Thunderbolt XL 300 ac/dc job. It blazes away real good. And I don't have it cranked up very far. A cheap wire feed would probably work fine for the trailer pockets with a couple of passes but it wont penetration into the side rails very good.
As far as the MIG stuff goes. Don't forget that if a person goes for the gas. Theres the deposit on the bottle if you don't have one. That would kill a good chunk of your $250 budget. I picked up another bottle with some tri-mix to weld up a stainless exhaust for a motorcycle. By the time I was done it was $37 gas, $165 deposit on the bottle which I will get back when I turn it in, $17 for a 2lb roll of stainless wire. Used on a Miller 175 MIG. It does weld beautiful.
thx
Jim
   / Welder Selection Help #24
Not sure what 220(volts?) your refering to but I have a Millermatic 251 that does 1/2 in a single pass. There are bigger more powerfull Migs. The 251 is about four times as much as the price you have listed.
   / Welder Selection Help #25
The new model from Miller, can't tell you the model number. Sells new for about $725 complete as I've stated.
   / Welder Selection Help #26
The price range will eliminate a new TIG unit but I have to say TIG is not bad at all!
My office has several small lincoln inverter welders that are used with TIG setups to weld everything you can image.
I learned on the job on these TIGs and am amazed at what you can do with them. Heavy steel and stainless steel is a daily operation with these 24x7 welders.
I found a link to one that is a bit more fancy than ours:
http://www.weldingmart.com/Qstore/p001729.htm
That does not include the gas and stinger setup I think......
Good luck regardless of what you get.. I have enjoyed learning to weld and am saving up for the exact same rig we have at the office!
   / Welder Selection Help #27
I was refering to my 135 mig.It does ok on 1/4 in stuff but thats about all. I do agree with you on the stick welding & making 2-3 passes. Weld 1 side, air arc the back side & weld it with 7018 & you have a very strong weld. The 7018 is a good rod.
   / Welder Selection Help #28
<font color="blue"> Heavy steel and stainless steel is a daily operation with these 24x7 welders</font>
I don't understand why you would choose TIG to weld heavy steel. It's slow compared to MIG or ARC and does cost a bit more in terms of gas. For all around welding of thin metals and various metals, I understand TIG is ideal.
I learned to weld with stick and was certified with 6011 root pass with 7018 filler.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2014 Chevrolet Tahoe SUV (A56859)
2014 Chevrolet...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Sterling AT (A56436)
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56436)
2015 Bobcat S650...
Deere 410L (A53317)
Deere 410L (A53317)
