Weld Table Rust?
/ Weld Table Rust? #1
gstrom99
Elite Member
Butler County, Iowa
Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
I recently bought a HF welding table. The top came well coated with waxy oil. I cleaned that off with solvent, but maybe I shouldn't have? I re-coated it with a rag soaked with motor oil.
What do you all use to keep the table from rusting?
/ Weld Table Rust? #2
I wonder about woolwax used for vehicle undercoat?
/ Weld Table Rust? #3
The 6 x 8 3/8ths thick table I have just gets wiped off with an light oil soaked rag infrequently. I'd never use anything that imparts a coating of substance on the table because you need a good ground between the parts and your ground cable to weld properly.
/ Weld Table Rust? #4
Think I wiped mine down few years ago with rag and light oil (30W) .... Don't give it much though as it does not get much rust... But gets use for all sorts of things in shop....
/ Weld Table Rust? #5
You might consider a light coat of WD-40. It is not a lubricant, its purpose is water displacement. In addition to spray cans you can purchase it by the gallon.
/ Weld Table Rust? #6
Bruce
/ Weld Table Rust? #7
CRC SP350 for anything containing iron. I've never got a can that seemed to spray worth a darn, so you have to spray then spread it around with a rag. You can also just give it a heavy coat. :D
/ Weld Table Rust? #8
Our shop is heated and cooled so corrosion isn't an issue as the RH is also controlled. It rarely gets over 50% RH anyway. Remember, anything coating a weld table prevents good electrical contact / conductability. If I do get a corrosion spot on the table that is detrimental, a quick use of my Harbor Freight surface conditioning tool removes it in seconds. I use that tool a lot anyway for removing surface scale and oxidation on parts to be welded. Having said that I use specific wheels for ferrous metals and specific wheels for aluminum and stainless materials to prevent cross confirmation which is critical when TIG welding aluminum. The tool is also excellent for removing MIG weld spatter as well as stick welding spatter.
/ Weld Table Rust? #9
I used to spray mine for years with spatter spray for welding, then I would wipe it with a rag, it worked like a charm
/ Weld Table Rust? #11
We would do that or get some tip-dip on a rag and smear it around like waxing a car.
/ Weld Table Rust? #12
I don't recommend using products like WoolWax or Fluid Film for this use (I am a big supporter of both products for the correct use)... However these products are "non-conductive" & should only be used on electrical connections after the electrical connections are made. This is posted by both companies on the sites... I personally would never use this on my welding table...
/ Weld Table Rust? #13
I rarely MIG weld, mostly TIG, so no spatter and if I do MIG weld something I have a spare plate I do it on I( clamp on a sawhorse. Most times MIG welding will be on a part attached to some other assembly anyway. TIG has no spatter at all.
/ Weld Table Rust? #14
Nothing... back when it was used all the time no issue plus a quick wire brushing or disc sander for dingleberries...
I made wood covers for the table and machine tools tables that have done well protecting the surfaces...
/ Weld Table Rust?
I've only tried TIG welding once or twice. I'd love to have one but I wouldn't use it enough to justify a hole new tool setup...
/ Weld Table Rust? #16
When I finish my welding project I sand the table with a flap-disc and spray it with the cheapest silicone spray from walmart and smear it around a bit.
/ Weld Table Rust? #17
Go buy yourself a multi process IGBT machine. Not that costly and one machine does it all except O/A. IGBT semi conductors have made multi process machines inexpensive and very viable as well.
/ Weld Table Rust? #18
I cannot and will not do that simply because the silicone spray residue will contaminate what I'm welding and that especially holds true with TIG. Dry steel table and controlled RH works just fine in my shop.
/ Weld Table Rust? #19
People that paint their finished projects don't like silicone either.
/ Weld Table Rust?
I might do that, but I'm unfamiliar with those. Do you have a brand/preference/link?
Rotomec Auger (A64127)
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
Massey Ferguson 573 (A64126)
Massey Ferguson...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
