Weight of water
   / Weight of water #51
I ran the number you have on my calculator and came up slightly different, so I rechecked by long multiplication by hand and confirmed what my calculator said - 3.35195 square inches. Then I re-did the calculations using pi to 10 digits and got 3.345871574 but since we started with 3 decimal places for pipe diameter, the result should be 3 also, so 3.346 square inches. I went thru and checked the rest and they're all close enough to what I get, it doesn't matter. I end up with a little over 30 pounds as well.
Thanks! :thumbsup:
   / Weight of water #52
You calculated volume of the outer pipe wrong, you should have used the area you calculated in the first step, not the diameter.
Please be a little clearer, highlight it in red or something, as I'm a little bleary eyed. :p :drink:
The OP said only the area between the outer wall of the small pipe and the inner wall of the large pipe would contain water.
So I had to first figure the volume of the large pipe inner cylinder, and remove the volume of the small pipe outer cylinder.
That gave me the volume of the space between the outer wall of the small pipe and the inner wall of the large pipe.
I divided that number by the number of cubic inches in a gallon.
Then I multiplied the number of gallons by the weight of a gallon of water
   / Weight of water #53
I have not had any Captain Morgan and Dr. Pepper but I'm to old to scratch this answer out even with a calculator.
So I use a couple of on line conversion calculators to get the weight of water (at 40 degrees F is just a guess for a well) and the answer I come up with is 86.595 pounds.
First is for a "Tube Volume Calculator": where d2= 2.067" and d1= 1.315" and the length is 100' which equals to 1.3871353296075 cubic feet.
Second is for a "Water Weight Calculator" : where 1.3871353296075 cubic feet equals 86.595 pounds of water at 40 degrees Fahrenheit.
Tube Volume Calculator:
Volume Calculator
Water Weight Calculator:
https://www.thecalculatorsite.com/conversions/common/water-weight.php
Maybe this helps a little and does not confuse the answer the OP was looking for?
Anyway, enjoy your Captain Morgan & Dr. Pepper (I do drink Dr. Pepper),
KC
edit: for the water weight calculator you will have to change the "convert from" to Cubic Feet [ft3], and add in 1.3871353296075 for the volume, and change the water temperature to 40F, and then convert to get the pounds of water answer of 86.595, because the link has wiped out this information.
You didn't subtract the space the inner pipe takes up full of air inside the large pipe. I did that as well the first time and came up with 80 something pounds as well until the OP clarified that water will only be in the outer jacket and not in the inner pipe.
   / Weight of water #54
Can anyone tell me how much the water might weigh, no bourbon and whiskey involved :dance1:
30.3576 pounds
Disclaimer, I'm not a mathematician, but I did sleep on a waterbed last night. :drink:
   / Weight of water #55
Assuming that a column of water 100 ft tall needs to be pulled up or lifted. Figure .433 lbs/ft as other have stated. So
100 ft height would be 43.3 lbs per square inch of area of water column.
Pi x the radius Squared for area of circle. Do the math for larger diameter column. Deduct the smaller pipe from the pipe and
come up with the residual area in square inches. Multiply times 43.3 for your answer.
I found the residual area to be 3.35 less 1.35 for 2 square inches of area.
So 86.6 lbs. for 100 ft column. Or . 866 lb. per ft.
   / Weight of water #56
I have a piece of 3" galv. vent pipe 48" long for a bucket. Still need to attach a piece of inner tube and bottom to it for lifting water.
In a crisis scenario this will yield about 1.5 gallons per trip cycle. One toilet flush, pot of water for dishes or whatever. Better than not
having anything without power. My water level is about 95 feet below casing. So about a 20 lb. pull on a rope for this I have everything on hand to complete a manual windlass for it if it becomes necessary..
   / Weight of water #57
Agree with what bcp first said: weight of water, diameter of pipe, length of pipe, does not matter. Only matters how high you are trying to lift the water.
There will be piping losses requiring more pressure the faster you try to push the water.
Water head tables: Water Pressure and Head
   / Weight of water #58
You need to read the thread to answer in a meaningful way. All of us understand water pressure and head but there is a different question being asked.
   / Weight of water
30.3576 pounds
Disclaimer, I did sleep on a waterbed last night. :drink:
That would make you an expert than I guess, Thanks, 30 pounds I can lift no problem
   / Weight of water #60
If you're using a sucker rod pump with a cylinder at the bottom of the well, you ARE lifting the entire weight of the water above the cylinder, not the static head pressure. The deeper the cylinder the bigger windmill you need to lift the water if the cylinder diameter remains constant.
Redirective Crash Cushion Guardrail (A55852)
Redirective Crash...
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2021 Deere 333G (A53317)
2021 Deere 333G...
2006 Ford F250 (A56858)
2006 Ford F250...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
