Weight of chains?
/ Weight of chains? #1
wedge40
How much do chains weigh? I've got 16.9-30 tires. Give or take 10lbs.
Wedge
/ Weight of chains? #2
It would depend on which style chains you need.
As an example, my Deere 4400 has 41x14x20 turf tires. I have 4 link ladder style chains. Each chain is about 70 lbs (+/- a few lbs).
/ Weight of chains? #3
I've never weighed mine, but I'm pretty sure they're not as heavy as Roy's. I'd guess 50 lbs per rear tire chain (on R4s).
/ Weight of chains? #6
Depends on how large a link, size of tire, type of chain layout.
I just welded a "U" shaped set of horns on my 3ph "T" bar to hang a single skidder chain from for a quick and simple ballast. That one tires' worth of chain weighs 550lbs.
/ Weight of chains? #7
It does depend a lot on the chain. I have 28" tires and chains made from 3/8" links with ice studs on each link. I can't hardly pick up an entire chain all at once, which makes mounting them a bit of a wrestling match. I love the bite and ballast they have though. If I were doing it over, I might look for a lighter chain just for the ease of mounting.
Dave.
/ Weight of chains? #8
Mounting a tire chain is like trying to stick 80 pounds of warm Jello to a wall.
/ Weight of chains? #9
Ain't it the truth.
I use the method of jacking up the rear of the tractor, put a piece of scrap light chain through the wheel and use the tire leverage to pull the chain around onto the tire. Then lock the brakes and get the chain ends linked together. It's a lot of pulling and tugging for sure. Once they are on, they stay on until the snow is gone. :laughing:
Dave.
/ Weight of chains? #10
My set of chains weighed 240 lbs a pair to fit my 49.9x24 tires. They are 3/8" links. I never pick the whole chain up though. I just lay them out on the ground behind the tire. Jack the tire off the ground, place one end on the tire then turn the tire by hand and the chain just wraps around the tire. It's just a matter of connecting the ends.
/ Weight of chains? #11
I have 2-link ladders (3/8") for 41x14x20 turf tires. They weigh 80 pounds each. My 2-link V-bars on the front (27x8.5x15) weigh 32 pounds for both.
JayC
/ Weight of chains? #12
My ladder style for 14.9-24's probably weigh 200 each.
I wrestle with them as little as possible to install them. I lay them out on the ground, drive over them and then pull the ends up on the tire and hook 'em up. I usually have to snug them up after a little bit of use...
/ Weight of chains?
I went to the source. Tirechains.com
I asked the weight of 16.9-30 Duo-Grip V-Bar and was told they weigh 186lbs for the pair. Or 93 lbs each.
Wedge
66'' SKID STEER BUCKET (A61572)
66'' SKID STEER...
2019 JCB LSB72 Compact Track Loader Skid Steer (A61572)
2019 JCB LSB72...
4022CFL (A59228)
4022CFL (A59228)
2007 International 8600 Parts Truck (A63689)
2007 International...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2024 John Deere 333G Tack Loader (A63111)
2024 John Deere...
