Weed eater getting gas into crankcase.
/ Weed eater getting gas into crankcase. #1
Bwgad96
Huntingtown,MD
Wayy to many.
hi to all, I had a customer bring in a weed eater brand trimmer. He said it wouldent start and needed new gas lines. I replaced lines and still wont start. Getting plenty if fire, runs with filter and exaust removed, but as soon as I reinstall them, no go. There is fuel coming out the exaust port in big droplets, and the crank fills up. Any help appriciated!
/ Weed eater getting gas into crankcase. #2
Maybe a carby kit and see how much compression. Just put you finger over the spark plug hole.
/ Weed eater getting gas into crankcase. #3
Sounds like bad rings. For the price of fixing it he' s better off buying a new one.
/ Weed eater getting gas into crankcase. #4
If it isn't any good should be good for parts. Two strokes are one of the easy motors to work on in my experience. Just temperamental at times.
Sent from my LG-P705 using TractorByNet
/ Weed eater getting gas into crankcase. #5
CHECK THE EXAUST FOR BEING PLUGGED. MUD WASPS BUILD A NEST IN MINE AND WOULD NOT START.
/ Weed eater getting gas into crankcase. #6
The carb is mostly just a diaphragm, usually 4 screws and it is good to go. Take it out and take it with you if buying locally, or buy it online.
/ Weed eater getting gas into crankcase. #7
If it will run without the muffler check the spark arrestor in the muffler for carbon build up.
41in Metal American Flag (A65583)
41in Metal...
Mayrath 30' Auger (A66285)
Mayrath 30' Auger...
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
NEW Wolverine SP-15-84W Snow Blade (A62679)
NEW Wolverine...
6' Picnic Table (A66408)
6' Picnic Table...
2009 Vicon 2400 9ft. 3 Point Disc Mower (A65640)
2009 Vicon 2400...
