Weather enclosure on canopy
/ Weather enclosure on canopy #1
Hillbilly
Platinum Member
Anyone have any ideas on where to purchase or how to make a weather enclosure that could be built by incorporating an exsisting canopy?A removable type,something that would look good?
/ Weather enclosure on canopy #2
Not meaning to be funny, but what "weather" are you trying to "enclose"?
/ Weather enclosure on canopy #3
Shouldn't be that hard to make/have made a canvas/vinyl cover to snap onto your existing canopy. Using something such as 3/8's steel rod (or 1" sqare tubing?) for frame and door frames. The front windscreen panels would be the hardest to fabricate, but with a little tinkering, I would think doable. It seems the lower connecting points would be the most ticklish to figure out.
/ Weather enclosure on canopy #4
Polycarbonate (lexan) would make good windows. Be sure to wash them clean with a hose instead of wiping off mud so the don't scratch.
An upholstry shop could sew up the vinyl/material The cloth used for boat sail covers could work.
I have also thought about finding some very thick clear vinyl sheet and just let the vinyl's weight hold it down, or add metal at the bottom for a weight. Have you ever seen the clear vinyl stip doors that are used in refrigereted warehouses? They drive fork lifts right through them without opening them. Another place I have seen material is the clear green vinly sheets that fabrication shops put around welding booth areas.
JRPoux
/ Weather enclosure on canopy #5
if there is an awning shop or canvass shop anywere in your area the can make one or sell you the materials to do it.
Yes there are lots of possibilites. I may not get to it this fall.But it is something to think about.
/ Weather enclosure on canopy #7
Hillbilly,
Have you seen this heater cab that TSC sells? If they have it to fit the 4400, looks like it wouldn't leave much space between it and a canopy and not sure you could make up anything yourself for $165.99
Hoss
Good post Hoss!!!!
2016 Hyundai Box Trailer (A62613)
2016 Hyundai Box...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
Hedge Posts (A65640)
New/Unused Outdoor Propane Patio Heater (A65583)
New/Unused Outdoor...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
